FYI found the cause of my death wobble
supermike
mike
Irvine CA
18 JLUR 6 speed
My jeep has a 2.5 inch aftermarket lift. it's developing a death wobble so i re-torqued all bolts and no help. so i called my nearest dealer to let them take a look just to save time. called, saying i have aftermarket lift and its ok for my to pay labor, confirmed and brought to dealer 8am on Tuesday. On Wednesday 5:56 pm, they called me, "oh we cannot work on your vehicle, since its not oem and not modified by us." I said, "ok, i'm ok to pay labor cost. " "no, we cant work on it, and it's ready for pick up, oh we close at 6. sorry" WTF is going on with jeep dealerships? i get nothing but bs story from them.
So i took it home today and on the way home picked up an large channellock from home depot and found the cause. it's the ball joint connecting to the pitman's arm, on the drag link, hope this helps.
fat_head
2018 JLU
Fix it and report back!
Crusifix
West Virginia
2019 JLU Rubicon 2.0T Hurricane
Easily could be the culprit. Jack the font end up and wiggle one of the tires back and forth a little bit and see if there is any lateral play in the link.
NFRs2000NYC
NYC/NJ
2014 Jeep Wrangler Unlimited Rubicon
What you did is a bandaid fix. You correctly identified the problem, but the problem is the actual joint inside. Tightening it down will help you short term, but the joint will continue to degrade. You can see Jim (owner of dynatrac) talk about this on way of life's recent video, he mentions specifically that joint. The solution would be a better quality drag link with better joints.
supermike
supermike
mike
Irvine CA
18 JLUR 6 speed
  • Thread starter
  • Thread Starter
  • #5
I only identify the culprit. To let the forum member know. No where did I say I fixed it. Still waiting for a synergy heavy duty drag link kit.
supermike
supermike
mike
Irvine CA
18 JLUR 6 speed
  • Thread starter
  • Thread Starter
  • #6
There is none. Only loose point was here. Replacement in mail already.
LABLUE
Craig
MI
2018 JLU, 2019 Ram 1500 North edition
CDJR Master Tech
Check it with the wheels on the ground, Jeep running and have a helper wiggle the steering wheel back and forth to see if there's any movement.
Up and down doesn't neccesarily condemn the linkage.
NFRs2000NYC
NYC/NJ
You're right, my apologies. For some reason, I thought you tightened that nut above the joint.
californiajeeping
JLUR
Check it out at 4:14. Same thing. Mopar has a new part number with a new and improved inner drag link, but an aftermarket is probably even better, but then there is the warranty issue.
HiJinx69
Richmond, VA
2018 Wrangler Sahara Unlimited JL, 2014 Mazda 6, 2010 Honda Odyssey, Yamaha FZ-09
Yeap, two days ago I discovered mine was shot as well. These are crap ball joints! Were they going to check the ball joint? Did you know it was bad before or after the visit? Maybe getting an aftermarket link would be a better option than stock. I meant, aftermarket has to be better than stock. Good luck!
Crusifix
West Virginia
Are the ball joints in these links able to be popped out in exchange for a better one...Strike that, might as well just get an aftermarket link at that point and upgrade the whole deal.
californiajeeping
JLUR
But many have reported that their dealerships will not work on steering issues if it has aftermarket drag links, aftermarket track bar, aftermarket steering stabilizer, aftermarket non-Mopar lift, etc. So with all of the steering boxes - new and old dropping like flies, they won't touch it if your steering box is bad.
Crusifix
West Virginia
Steering box goes out..pop the OE bar back on. I should preface this with...You should of course know how to work on your own vehicle, so that you can restore to stock if something else fails, and or have a good dealership relationship.
californiajeeping
JLUR
Good point, but that works for one or two parts, but many have an aftermarket, non-Mopar lift. That would be a pain. Plus, a good relationship depends 50% on the dealer. No matter how nice you are to the dealer, or how well you can walk on egg-shells, you may or may not even be able to have a good dealer relationship.
HiJinx69
Richmond, VA
Let's say you have all these upgrades and your steering box goes bad and you need a new one. You know going in that warranty will not be honored and need one, paying out of pocket, they still won't touch it? WTF! What do you do at this point then?
D&C Designs
