Fuse box on 2021 Sahara "again"
Rusty Teeth
York,PA 17408
2021 JL Sahara Altitude
Electronics Tech/ Fabricator/ 5G Fiber Optic Cellular Tech
Have 100 miles on my 2021 Sahara, few things I learned from my 2018 first JL to check. Once again the Battery terminals and fuse box needs gone over. I had a post where few of the distribution terminals were loose or shorted out. Those have been nicely tightened and aligned. The battery terminals were bugged up a bit ad twisted. The positive red insulation flap was hanging on the harness not covering the terminal. Slight adjustment allowed it to seat between battery and terminal. Also will place a trickle charger on the main battery and the ess battery. Took 2 days on a small trickle charger to get both charged. The fuses also again must be seated. See video if it will allow me to upload. EVERY fuse has a click sound as a firmly press it fully seated. The smaller amperage fuses were nearly seated, but the larger. Were not seated! The relays also were not seated! some may be 5 to 6 mm raised. You can hear a very satisfying click when each is seated.
