Fumoto F106 M14-1.5 Drain Valve for the Wrangler JL
FatBoy01
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #31
snipe:
I won’t be purchasing one until getting an aftermarket skid plate.
Rather then pair up the Fumoto install with the skid plate install, you might be wiser to pair up the Fumoto install with the oil change/any of your oil changes you do, prior to the skid plate install. Yes, the Fumoto Oil Drain Valve is a terrific adjunct.
Brad41
S. Indiana
18’ JLUR firecracker red
How far does the regular valve protrude from the bottom? Anyone install it have pics?
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #33
Unclear exactly what you are looking for. Please explain..
I can tell you that the F106S when installed on the JL/JLU, will protrude out exactly one inch from the oil pan. If you are crawling rocks with your JLU/JL you would not want to have this valve unless you were also running a skid plate.
F106S installed
Brad41
S. Indiana
F106S installed
Yes, that does help. Thank you
JIMBOX
JAMES
FERNLEY NV
2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
I've been using FUMOTO VALVES FOR over 15 years and I use the "EZ" FUMOTO on my Ram/Ranger/JKUR and I'll be getting the FUMOTO F106EZ for the JL-
It's a much more adjustable NIPPLE and can be adjusted for whatever the drain requirements--especially when the skid plate limits your "PLAY ROOM"
Whatever
JIMBO
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #36
Whatever
JIMBO
Jimbo... I think you mean the F106SX: New Generation Valve with 14mm-1.5 Threads. That the adjustable flow Fumoto to use with the JL/JLU's 3.6L .. Yes, good choice if you have a skid plate. Yes, adjustable position in regard to flow..
F106SX
JIMBOX
JAMES
FERNLEY NV
Probably so, that's a new one, I've been using the EZ FUMOTO FOR MY 3.8L/5.7L/4.0L and you do really need the drain portion to be adjustable, because of skid plate restrictions-
It appears that, for the jeep 3.6l---the FUMOTO adj. valve is gonna be 'F316L" and either one is adjustable-
Good day
JIMBO
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #38
Good day
JIMBO
@JIMBOX ... Both the older generation, F316L: FUMOTO VALVE W/90°L-NIPPLE M14-1.5 THREADS and the newer generation offering the F106SX are aok to use on the JLU/JL with the 3.6L. Both will give you the swivel you seek. Personally, I like the look/design of the newer generation offering. Seems beefier and maybe a little less footprint?
Whatever way you go, the Fumoto is a terrific adjunct!
F316L
JIMBOX
JAMES
FERNLEY NV
Absolutely KORRECT--and-
As much as I've protected my FUMOTO VALVES, off-road-I still keep the original pan drain plug in a"zip lock"--just in case the UNBELIEVEABLE breakage happens-
I've been safe for all these years so I'll knock on wood-
COOL
JIMBO
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #40
COOL
JIMBO
Yes, I too keep my factory oil drain plug in a zip lock bag, stashed in the vehicle. I have used Fumoto's for many many years and never an issue.
JASPER
Wayolife Sucks
Tucson
2018 JLU Rubicon and 2014 JK 2dr
got my valve just waiting for 1st oil change.. hopefully these manufacturers get there pans out soon.. jeez.
Yellow109r
Michael
Oklahoma
2018 Jeep Rubicon JLUR, Bright White
Aircraft Industrial Engineer for the DoD
awesome
Magnus579
Mansfield
2018 Jeep Wrangler Sport S JLU
I installed the Fumoto F106SX (the version that lets you adjust orientation) this weekend during the first oil change on my JLU Sport S. The wind was blowing 28mph and, even with a fill container, I made a mess on the driveway. I look forward to the next oil change and being able to use a tube to control the drain. Here is a photo after the install - I will likely need to change orientation/fitting once I get skid plates:
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • Thread Starter
  • #44
@Magnus579 Thanks for taking the time to post here in regard to your Fumoto. The pic is especially appreciated!
Looks good! For those that view the pic above, do know that the white nylon fitting attached to the valve body, is not on there all the time. You only connect the nylon fitting (presses on) when you go to change the oil. That nylon fitting is what you hook your drain hose to.
Magnus579
Mansfield
I was wondering about that (leaving it on at all times)...the theory was that if I attach/remove it every oil change, it may loosen against the fitting...does it hurt to leave it attached (short of the chance it could get caught/break)?
Gibson Leatherworks
