Fuel Quality, Temperatures and MPG’s
NCJL
EastBay
2020 Rubicon
So for the first time I fueled using B20. I only topped off a half a tank. I have always used D2 until this time. I noticed a drop in MPG.
I remember reading the owners manual when I first purchased saying something like MPG and maintenance will be affected by the use of bio mix fuels. I always used D2 with this in mind.
So this got me thinking. What type of diesel fuel are others running? Could this be a reason for the differences reported with MPG?
Also in other Diesels I have owned. The BioDiesel fuels always seemed to make the engine run hotter than D2 would.
Once again is the type of fuel used adding to the higher temps some are seeing with their ED?
I have used D2, except for 1 recent 1/2 a tank of B20, exclusively. I seem to have higher than the normal MPG and have never overheated when pulling my 4K trailer. I pulled the Grapevine in SoCal with 112 ambient temps no issues.
Just thinking.
NCJL
NCJL
EastBay
2020 Rubicon
Not sure exactly. I was fueling at one of my normal D2 spots. I fueled than noticed they had changed to B20. I figured only half a tank, shouldn’t be a big deal.
I’m going to break out the owners manual later today to verify. Do not remember the specifics, just my takeaway after reading to only use D2.
CWRUYOTE
CLE
2021 JLURD
From the 2021 diesel manual, starting on page 567--max of 5% biodiesel blend, but up to a 20% biodiesel blend can be used, provided oil's changed more frequently:
Jeep Wrangler JL Fuel Quality, Temperatures and MPG’s IMG_3907
GSLSE21B
Fair oaks
2021 jLURD
B20 will consume styrofoam and your fuel system warranty 👍
NCJL
NCJL
EastBay
2020 Rubicon
So I renamed the post. Trying to get more traction with the type of fuel we are using in our EcoDiesel’s.
I had extra time this morning. Stopped by the place that changed from D2 to R95. I haven’t searched what R95 truly represents, I did take a picture of what was listed on the pump. Not good. Minimum 20% bio diesel.
The half tank I used of the R95 averaged 3 MPG less than normal. I do the same exact drive during the week. Mostly short trip city type driving. Engine temps are never consistent during this time.
I drove this bad tank of fuel to as close to empty as I could, fueled up with “D2” from a different station. Noticed a slight difference, better. With this tank of fuel I did a 300 mile round trip to the Yosemite area. I wasn’t towing anything. This type of trip would normally see 29 plus MPG if I’m trying to get good MPG. I only got 27 MPG.
In my area I’m noticing a price difference between stations (about 12) of about .30 cents per gallon. The lower price usually has advertised bio diesel. Some lower prices still say D2. The higher prices only list D2. Thinking even though it says D2 maybe not!
We, the forum, have also proved Dealers and Oil change Stations don’t use the correct oil a lot of the time.
Just thinking.
Not using real D2 with the proper spec oil may be the biggest factors with MPG, Engine Temps and Engine longevity.
NCJL
NCJL
EastBay
2020 Rubicon
I have about 1.5 hours of BART train time during the week on a daily basis to try and educate myself. I’m using this time lately to learn about Diesel fuel quality.
First, you can find info that will agree with whatever you want your opinion to be.
With this in mind I’ve mostly read what the Manufacturers of Diesel Fuel have published along with others that use ASTM standards with documentation showing the testing to meet or exceed the ASTM standards using ASTM testing procedures.
In regard to fuel additives and engine oil.
Most companies do not provide any documentation showing what they claim or at least not easily accessible documentation.
I’ve only found one fuel refiner that published its own Diesel Fuel Quality document (Chevron). Others refer you directly to ASTM D975, without interpretation.
Summarizing.
Diesel fuel has about a 10% window of quality depending on many factors leaving the Refinery. After Diesel Fuel leaves the Refinery additives may be mixed in by the various handlers for many reasons Fuel Stability, Fuel Conductivity, Antifoam, Contamination control, flow agents and so on.
ASTM D975 is the minimum standard for D2. Different manufacturers do different things to meet this minimum. Doing this changes the mix in regard to Cetane, Lubricity levels, ETC. For example ASTM D975 standard for cetane is 40. Do to many different factors a refiner may increase the cetane level to 46 to control another minimum regarding smoke. Lubricity levels are also not consistent, they only must meet the minimum. Lube levels are changed once again for many different reasons.
All decisions made in the manufacturing of diesel is made with cost as a priority. I’ve seen this statement mentioned several times in my reading.
Engine manufacturers blame fuel and fuel manufacturers blame engine manufacturers.
Read many times that a more modern ASTM D975 standard is needed.
Engine Manufacturers Association and Fuel Manufacturers have meet to create this standard with no agreement. Premium Diesel was an idea that didn’t take off.
D2 in California is generally considered to have higher Cetane levels due to lower Aromatic requirements. Higher Cetane levels lower Aromatic levels. Lubricity additives by Refiner are also common in California. Another way to lower Aromatic levels is hydrotreating further than needed to remove Sulfur. Doing this requires adding additives to raise Lubricity.
Most info is old. The Chevron document was dated 2007 and easily found.
Fuel Manufacturers get a tax credit up to a $1 per gallon for renewable/bio diesel.
I’ve never been a big fan of fuel additives. Try to only use when definitely needed. After doing all the reading with Diesel quality I’m starting to think differently.
NCJL
NCJL
EastBay
2020 Rubicon
Just drove the JLURD with trailer to the Yosemite area. 140 miles one way. Camped now will do the return Sunday.
Ambient temps in the 90’s.
Highest oil temp was 246.
Highest coolant temp was 228.
21 mpg.
I did use Lucas fuel stabilizer with this tank.
This trip does have about a 7 mile 6% grade. This is a single lane with speeds from 20mph to 35mph. Lots of 90 degree turns.
Pulling 3900lbs trailer.
RPM mostly in the 2K range.
JL Diesel
Tim
La Mesa
‘22 JL Diesel Sport S
Just thinking.
I just got a new diesel and I’m in SoCal and have been thinking about exactly what you’ve talked about in this thread. Since it’s been around a year since making this what have you concluded? Did you go back to just D2 or stick with B20 or mix and match whatever the station has? The dealer filled me up when i picked it up with who knows what then my first fill up last weekend was B20. So far I don’t see a difference but again I don’t know what I started with.
garykk
Gary
Southern NM
2022 JLURD
Just thinking.
Jeep Wrangler JL Fuel Quality, Temperatures and MPG’s 66F62EB2-6BE5-4C33-AE07-EAA445CB3487
Renewable diesel is a hydrocarbon diesel fuel produced by hydroprocessing of fats, vegetable oils, and waste cooking oils.
In other words your Jeep will smell like 🍟
GO_RV
JC
Pennsylvania
2022 Wrangler Sahara JLU
I would avoid biodiesel.
also, I’m surprised how hot these diesels run.
my motorhome only gets to 210F climbing Homestake Pass in Montana and the Big Horns on I 90.
tranny gets to about 220f.
but it’s a 45,000 lb motorhome pulling my Jeep.
zouch
Berkeley, CA
XJ, JLUWD
Renewable Diesel and BioDiesel are not the same, even though they are both BioFuels.
BioDiesel is made from Vegetable Oils (usually recycled used oil), while Renewable Diesel is made by a completely different process that is much less <ahem!> vegetarian.
confused yet?
Renewable Diesel may or may not have the same Lubricity that BioDiesel does naturally, and although use of BioDiesel is allowed up to a 20% blend per our Users Manuals (and my communications with our vehicle manufacturer) i haven't seen any clear recommendation yet WRT the use of Renewable Diesel; the most i've seen from JeepCares so far was that Renewable Diesel was "not recommended" though no reason why was ever provided.
there is much speculation that running a BioDiesel blend may help provide some of the Lubricity lost when ULSD was implemented in the USA, which the CP4 pumps in our EcoDiesels would probably benefit from. (compare the failure rates of the CP4 pump in the US with those used in other countries that use fuel that isn't as 'dry'.)
looking at the stickers on the pumps of the major fuel providers now i'm seeing a lot of stickers with vague statements like "May contain between 5 & 20% fuel made from Biomass", which really doesn't tell you how much of anything is mixed in with the #2.
i never saw BioD make my old Mercedes run any hotter, but it did always cost me about a 10% hit in fuel economy. i put roughly 100K miles on that car running straight (commercially produced) B100 BioDiesel.
and no, as much as people like to joke about it, while it did smell different running B100, it never smelled like French Fries. (i don't know where that got started.) what it did smell like, rather, was like a hot wok grilling veggies.
the guys who were running straight Waste Vegetable Oil? those cars smelled distinctly like hamburgers grilling. ;)
