Sold: Louisiana FS: Teraflex Alpha tire carrier
Dodgeman70592
Jared
Maurice, LA
2020 JTR, 2011 Challenger SRT IE #94, 2023 392XR
Just received this in and installed yesterday. When I went to put tire on, found out that my wheel hub bore is too small to slide on to mount. I already had torqued the studs in the holes for 37” tires. I will leave them in there for next owner. There is 2 jam nuts included for you to take studs out of holes if you want to run a smaller setup. It will come with all hardware and blue threadlocker. I have taken close up shots of the slight scratches on the nose from trying to mount my tire. My loss is your gain $250 shipped conus.
millerjl
Chuck
San Diego, CA
JLU Rubicon
Looks like Teraflex has removed this from their website. There is still a pic but if you click it, says product not found and if you do a search, nothing comes up. I was looking into this one but have hub centric aftermarket wheels. That sucks.
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
Andrew05LJR
Andrew
Ft Lauderdale
2019 JLUR
I bought from Northridge, they still showing product info
https://www.northridge4x4.com/part/...stable-spare-tire-mounting-kit-for-5x5-wheels
Install:
http://www.northridgenation.com/teraflex-alpha-hd-tire-carrier-for-the-jl/
I haven't contacted Northridge about it not fitting, doubt they would take it back now that I've tried mounting it. This is definitely something that should be stated in the fitment section from Teraflex though. They need to have a min hub bore requirement.
What size hub bore do you have? I’m interested in this but plan on AEV Borah and KMC Machete
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
I'm running ATX Ravines in a 17x9 -12mm, specs say 71.5mm
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
i have same Alpha Carrier on my JL
if the wheel is JL specific it should fit with no problem with this
maybe you have Smaller hub ring on the wheel ? , its weird....
by the way i have Mopar Beadlock wheels Bore size 71.5 also
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
Not sure what's up but it's definitely too big to slide through, by probably close to an eighth all around. The wheels weren't JL specific or anything. Just a 17x9 with a 5x5 pattern
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
ic.. hope u find a good solution with the seller :)
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
Yeah, I wasn't gonna even try to talk to Northridge about it, figure they would tell me that since I bolted it up and torqued in the studs that it's mine now lol. That's why I'm just trying to sell myself.
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
All PM's replied to
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
Bump
Dodgeman70592
Dodgeman70592
Jared
Maurice, LA
All PM's replied to.
Considering milling the nose piece down now to fit my wheels if this doesn't sell soon.
Pending tropical storm/hurricane in my area will likely prevent me from shipping this till early next week
KansasJL
Kansas
2019 Sting Grey JLUR
Im assuming this has sold?
