FRS/GMRS radio overhead mount location
sourdough
Ben
white JLR
wanderer
Not needing the review mirror, can’t see out the back because of rear cargo shelves, made this location possible.
Once the mirror is removed there are two bolt studs about 6” apart fixed to roll cage. I bridged them with a metal strap and mounted the radio bracket to the metal strap.
Antenna mount is an aluminum l bracket I made. Not sure the antenna location will work very well. Recommended location seems to be on the roof top.
VA72mlibu
Eric
Alexandria, VA
2019 Mojito! JLR; 1972 Chevy Malibu; DHC-7 & BeechCraft King-Air (operated, not owned)
Hmmm...that makes me wonder if one could fab a bracket that tucked the radio tight up against the bottom of the rearview mirror? Anyone ever seen such a thing?
sourdough
sourdough
Ben
white JLR
wanderer
I went this route. Remote head radio. Brain is under glove box. Used a trigger 6 switch mount, $35 on Amazon. Cut an ABS piece to mount the head to.
I like this mod’d switch panel idea. looks a little tight to the Freedom latches but not bad. Your idea works for everyman that needs/wants the rear view mirror. Your idea is way better than that $110 cross bar on another forum.
VA72mlibu
Eric
Alexandria, VA
sourdough
sourdough
Ben
white JLR
wanderer
Any product developers listening:whatsgoingon:
jawest12
Aaron
WV
jeepinwv.com
2020 JLU Rubicon, 2018 JLU Sahara
Yeah, that solution definitely wasn't for me. I'm 6'2", with a long torso. I don't even need the sun visors as is, lol. That bar would very much be in the way.
Dank
So. Cal
I wasn't happy with what was on the market for an overhead radio locations, so I asked my friend over at Retro Fab to build me something custom. It keeps the radio high enough to be out of the way. I still need to wire it in, but now have the mount that works for me.
Extreme Terrain
