Front wheel opening "Splash Shield" flimsy
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
I just return from a trip to Moab. The high daily temps in Moab were 98 - 106 degrees F. On the return trip home I set the cruise on about 85 mph. Speed limit on I-70 is 80 mph. When I exited the highway for fuel, there was a rubbing noise near the left front wheel.
Turns out the HDPE splash shield is very flimsy and is not mounted securely. The dynamic air pressure from the engine compartment along with the high temperature air pushed the splash shield out into the tire. About 20% of the splash shield was ground away.
New splash shield: $94, plus I have to address the root cause.
Anyone have this happen to them?
Tool Guy
So Cal
2019 JLUR, 2020 BMW Z4, 2021 Tacoma, 2022 X3 M40i
If you can afford the gas that it takes to run 85mph in a Jeep Wrangler, you can afford metal fender liners ;)
Jeep JL Metal Fender Liners
I assume this is what you mean by "splash shield"
Jtclayton612
Memphis, Tn
2020 JLU Sport S
Tires eating the inner fender is a somewhat common issue, I just got high clearance inner fenders.
GATORB8
CLT NC
21 JLURe
Paramount makes an HD plastic set, but they’re as expensive as some metal ones.
