cmb
Yes, you order from their siteDid you buy direct from them?
RubitruxDid you buy direct from them?
Looks great - how are you liking the flipster?There’s a specific Mopar part that snaps into Rubicon steel bumper, in place of fairlead cover, if you are not running a winch.
I went the Cascadia flip up route
Mine does also - but only if the mounting is supplied by the manufacturer. If my steel bumper doesn't come with the mounting plate it is going platelessMy state requires front license plate and mine arrived with a license plate holder from factory.
They’ll mount it unless you ask them not to. (I asked them not to - didn’t want holes drilled, hence the fancy bracket I’m using, instead.)Mine does also - but only if the mounting is supplied by the manufacturer. If my steel bumper doesn't come with the mounting plate it is going platelessDefinitely a cleaner look.
That's an elegant solution.There’s a specific Mopar part that snaps into Rubicon steel bumper, in place of fairlead cover, if you are not running a winch.
Thanks for the info. I'll make to sure to let my dealer know I don't want holes.They’ll mount it unless you ask them not to. (I asked them not to - didn’t want holes drilled, hence the fancy bracket I’m using, instead.)
Where did you find the plate that mounts on the bumper behind the license plate holder and fairlead? Did come as part of the license plate holder?There’s a specific Mopar part that snaps into Rubicon steel bumper, in place of fairlead cover, if you are not running a winch.
