Front Driveshaft, depending on engine?
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Question for the gang:
As I recently completed the MC GC 3.5 on both of our Jeeps, I noticed that the exhaust is routed differently on the 2.0, as to NOT interfere with the front driveshaft. I was assuming to have to buy 2 new DS’. Looks like the only possible hit is the crossmember, but I didn’t see any issue during the install at full droop. Can anyone weigh in please? Posting a pic of both 3.6 & 2.0.
Thanks crew!
3.6
Jeep Wrangler JL Front Driveshaft, depending on engine? 52E9F113-3DBD-4988-85D9-18E8087D5CEC
2.0
Jeep Wrangler JL Front Driveshaft, depending on engine? 6A35E9DE-2EAD-455D-9F61-419DB2AC7325
Roky
Roky
Thanks crew!
3.6
2.0
I didn’t notice mine rubbing or hitting the exhaust, however, it does get close . I’m only 26-5/8 inch extended on my fox shocks, your probably 28 ish if you’re running falcon 3.3s. I switched my driveshaft out anyway I just didn’t want to chance it. I’ll be changing to a longer shock eventually so I didn’t want to worry over it.
Jeep Wrangler JL Front Driveshaft, depending on engine? D7E8FFD6-9537-4059-BBE4-360A7851712C
stil2low
Craig
Ontario Canada
2015 Jeep jk
The 2.0 being inline wont have a y pipe like the v6 does providing more clearance. You will need a new front driveshaft if your shock shocks extend past the 28” mark. It will come in contact with the small crossmember. The aftermarket shaft will run that crossmember as well at full droop if you use MC’s shocks or anything in that 30” range but engine trans skid will remedy that because most get rid of the small one. It’s only on the auto trans equipped Jeeps as a skid for the trans pan, manuals like your 3.6 don’t see it
jlewissystem
jlewissystem
J
STL
So, it sounds like I will need one on both, as the rock shocks hit 30, I think. Thanks for helping to confirm the crossmember!!
Roky
Roky
Hey Craig, Did you cut out your lca bracket on the axle to clear jamb nut at full droop, if so can you post pic?? Thanks.. sorry op for hijacking... :)
stil2low
Craig
Ontario Canada
2015 Jeep jk
I haven’t yet, I’m actually waiting for my shocks to come in before I cut since I’m just running the adventure arms. I never even thought to check my buddies Jeep with the MC kit if they touch or not. MC runs their arms backwards in compared to RK so the nut is frame side
Hopefully UPS fixes the truck and I see the shocks this coming week and I’ll let ya know haha
Jeep Wrangler JL Front Driveshaft, depending on engine? 1C90B62B-0C11-41E0-8A80-B78F7DB1E4DF
stil2low
Craig
Ontario Canada
2015 Jeep jk
No problem!
My buddy sent me this after he seen it and was concerned. At full droop with the MC shocks it hits the crossmember
Jeep Wrangler JL Front Driveshaft, depending on engine? 04E25890-40D3-4A20-99AF-6758A254AC1E
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
You don’t have to cut for jamb nut clearance since it’s on the frame side as mentioned with the MC lifts
Brett
jlewissystem
jlewissystem
J
STL
Thanks for more info. As Brett mentions, MC runs the jamb nut on the frame side, so 1 less issue there.:fist bump:
jlewissystem
jlewissystem
J
STL
I’m sorry guys I was referring to my rk arms, I knew @stil2low was running rk and I was seeing if he had cut his yet. My apologies for the highjacking.. :)
No worries...I smelled what you were laying. :ontheloo::)
