Front door skins popping and separating
WranglerUnlimited2018
Brendon
G-Town
2020 Jlur
Does anyone else have the front doors popping and coming apart. The door skin is definitely coming apart right where the new door closure is mounted.
MARSHMELLA
Kirt
FL
2021 JLUR
Military
A picture might help some to understand what youā€™re talking about....
SouthCo
MD
2018 JLU Billet Silver Sahara
Yeah a pic may help. My 2018 door skins look the same, inside around the seam and out, as the day I brought it home.
Brendon
G-Town
2020 Jlur
So there is no way to show you whats going on, the doors on the jl have a spring loaded door mechanism that assists in closing the door like a regular vehicle. This mechanism is mounted to the door internally with 2 nuts and externally mounted to the tub door frame with the single bolt you remove when the doors come off. The crinkling or popping sound is coming from the internal door where the mechanism bolts to the door itself. When you open or close the door the different layers of the door since its actually skinned with aluminum over another material is separating and causing the noise I am trying to explain.
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
Iā€™ve actually heard a noise on my 2021 that sounds very similar to what youā€™re describing. I notice it the most when washing the Jeep and pressing against the outside if the door.
Seems like itā€™s not hurting anything, so Iā€™ve learned to ignore it.
Brendon
G-Town
2020 Jlur
Yep, but ours is getting worst and worst. Probably have the dealer look at it when they are replacing the screen
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I had the popping noise - pulled the mirror and soaked the door cavity with silicon spray. The noise has since disappeared and not come back...,
JeepCares
Auburn Hills, MI
JL
Hey, WranglerUnlimited2018. Is this concern still present? If so, we would be happy to discuss further. Send our team a private message with more detail.
Kate
Jeep Cares
YYCSahara
BDLL
Calgary AB Canada
2019 Jeep Wrangler Unlimited Sahara 2.0T
This is a door manufacturing flaw. Nothing you can really do to fix it. There was a huge thread about it on here somewhere.
Brendon
G-Town
2020 Jlur
Kate
Jeep Cares
Yes it still is an issue. That would be awesome thanks.
JeepCares
Auburn Hills, MI
JL
Sure thing, WranglerUnlimited2018. To get started, send us a private message with more details; including the date of the last time the dealer diagnosed this. We will keep an eye out for your reply.
Kate
Jeep Cares
Brendon
G-Town
2020 Jlur
Ended up taking the jeep to the dealer and they did some kind of recall on the door jams but it only helped the passenger door. The driver door was the same and the passenger door was a little quieter.
