Jeeperz Kreeperz
- Jan 15, 2018
- New Hampshire
- 2021 JLUR 4xe
First Jeep. First portable fridge. Need some advice:
I just purchased a Dometic CFX 50W fridge, and have been trying to just plug-and-play with the OEM battery setup.
From what I’ve read, this should work, but I will run the risk of draining the starter battery if I left it on too long. Fridge has three settings for voltage drop shutoff: High, Medium, and Low. Instructions say to only use “High” if you are in a single-battery setup, and really worried about impacting the starting battery. “Medium” is for normal operation in a single-battery setup. “Low” is only for use in a dual-battery setup, where you are not concerned about how far your voltage drops.
“High” was of no use. Fridge would only work for less than an hour after shutting off Jeep, then the voltage would drop to the point the fridge wouldn’t work. “Medium” is only slightly better - Fridge stops cooling after a couple hours. Test was done for one week - most days the Jeep would be running for 30-minutes on my commute in the morning, and 30-minutes back home at night.
Question: Is the factory wiring to the rear 12V plug the problem? I bought the ARB wiring kit, but have not installed it yet, because I want to be sure this is even a viable setup with a single OEM battery. If it isn’t, no sense installing that kit, as I’m looking at the following total costs:
Single-Battery Setup:
$650 for fridge
$250 for fridge slide
$ 40 for ARB wiring kit
$940 Total for single-battery setup
Additional Dual-Battery Costs:
$550 guess for Genesis dual battery kit
$296 for Odyssey Group 25 battery #1
$296 for Odyssey Group 25 battery #2
$1,142 Additional Costs
I went with the fridge THINKING the total cost would be less than $1K. Now I’m getting into it, thinking my actual cost maybe more than double that, and deciding whether I should abort the mission, sell the fridge, buy a good cooler for $400, and redeploy the other nearly $1,700 on bags of ice and more mods to the Jeep!
Is anyone running their fridge successfully with a single-battery setup? Am I missing something?
$650 for fridge
