Freedom Panels Only
Cody6597
Elliott
Houston
Jeep JL Unlimited Rubicon
Hey everyone...new JL owner here. Anyone know if OK to run with hard top off but keep the freedom panels on? Getting yes and no searching the web and most of that is old info.
Thanks.
$uicide$hift
Masshole
I have never owned a hard top. Looking at videos I see where it should be possible. I would have your rear hard top removed and put the freedom panels in place. Once they are lock them down with the latches and that screw piece that goes between them through the sport bar. Push on them and see if there is any give to them where they may pop off from strong winds. If they are attached and solid I don't see where this would be an issue.
Give it a try.
Magnetdragon
Erwin
Tampa
Jlu!!
On my JK it was fine and ran it all the time. On my JL I tried it out but one latch on each side won't attach to anything and it didn't seem super secure (IMO) since it's not screwed down to anything anymore.
Cody6597
Cody6597
Elliott
Houston
  • Thread starter
  • Thread Starter
  • #5
Hmmm...I guess theft isn’t really a concern or at least not for me. I would most likely only do this with the doors on but hard top off. If I went doors and top off I would roll with a bikini top or something like it I think.
misanthrope
LI, NY
Schwinn Homegrown
Badass
Give it a try.
Except there aren't screws anymore. The Freedom panels rely on the clips to secure them between the windshield and the rear hard top. Without the rear hard top section, what would hold them in place back there?
See post #3
$uicide$hift
Masshole
See post #3
I have seen a few videos of the JL and when they removed those freedom panels they stated and showed a large circular handle attached to a threaded bolt in the center between the panels at the back of them. This was going into the sport bar I believe. Do you have that? What is the purpose of it?
misanthrope
LI, NY
Schwinn Homegrown
Badass
Don't know those videos, but definitely no more screw. The outer clips attach to the rear section, whereas the inner (middle) clips attach to the sport bar. But, without the outers fastened, it just seem too unstable.
Jeeptimus Prime
Bryant
NorCal
2016 JKUR
After numerous studies in rooms with many blinking lights and doohickeys that arc electricity also years of animal testing and that guy running on the treadmill with all them tubes Jeep has discovered you don't need the damn Freedom Panels without the rest of it! Sure... would it be nice, maybe, but can they sell you something else that can do it??? Yes, yes they can! :like:
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solutions Architect
I'll try to find the video, but some jeep reviewer said its "allowed" to run the freedom panels with no top and that its perfectly safe that way. I was trying to figure a time when I would want to do that. I mean if the Hardtop is off, the soft-top will be installed. Will I still carry my freedom panels with the soft top installed? I doubt it. I think if you need some shade, the spider shade seems like a better idea. (Or Soft-top up minus the windows, I think that is a cool look too. Someday I'll get my order and check it out for myself.
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
By looks of this video it would be doable.. The L locks that replace the screws affairs that were in the JK appear to latch/lock into indents on the sound bar itself.
$uicide$hift
Masshole
Yes I have seen those but also others where dealers are going over features of ones delivered on their lots. Somebody here with a JL in their hot little hands have a hard top that can say if this exists?
rallydefault
PA
'18 JLU Sport S
I have the hardtop. I may be understanding your question wrong, but there are no screws involved with the freedom panels. The panels are just attached by four clips that need to be swung away from the frame. Takes about 10 seconds to do that and lift the panels out.
dave.j.fisher
Macomb, Michigan
JLUR
On an older JK, I only had the hardtop, so this was appealing for me to do. I would run like that for weeks at a time. I can't image there are any safety concerns doing so, if only half of the clips are latched. I even looked into the duster cover for the back and soft window behind the front seats, but was told there will be leaks because there was no good seal between the freedom panels and soft window. I would think there would be a small market for this capability. I like the looks of the hard panels with the rest of the top off and not everyone has the dual top option. I bet its pretty common for someone to only have the hardtop. I live in Michigan, so we really only have about 4 months of soft top weather...but I still went with the dual top option...
BeeLDub
Brandon
Eastern PA
2016 JKU Rubicon Hard Rock, 2015 Cherokee Limited
Structural Engineer
Idk, it looks like the indents in the sound bar look like they're there to allow the latches to reach the back portion of the hard top. I don't think the freedom panels would be very secure without it.
Northridge4x4
