CarbonSteel
I have performed 3 OCs on my Rublcon thus far:
800 miles changed OEM filter with XG11665 (this one)
2000 miles (did not change filter) (1,200 Miles on oil)
5000 miles (changed filter) (3,000 miles on oil and 4,200 miles on filter)
At the initial OC (800 miles), I also installed a Gold Plug magnetic drain plug. At the 2,000 mile OC, it was clean, but on this latest OC, it had quite a bit of metal on it (and I probably lost a little because the plug clung to the pan when I removed it).
The XG was twisted slightly and I have seen this on most filters for the 3.6L Pentastar, otherwise it was in good shape. I do wonder if the filters are a little too long OR if the oil filter cap is tightened a bit too much. I torqued mine to exactly 25nm this time (I did not torque the cap for the XG--but I did not "he-man" it tight either).
A Mahle filter and Castrol Edge replaced this filter and oil and I will be moving to a 5K OCI from this point forward.
Enjoy!
Enjoy!
