Fox Reservoir Shocks - Front Reservoir Mounting Locations
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
I really think you are trying to solve a problem that doesn't exist.
I've had mine on for quite some time, done quite some trails, and zero issues in the factory location. The only deviation from the Fox instructions was to use rivnuts to mount them versus bolts and nuts.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Those hoses on the factory Mojave shocks are actually longer than the hoses on the 2.5’s. You won’t have enough hose to mount the aftermarket ones in that spot.
Jeep Wrangler JL Fox Reservoir Shocks - Front Reservoir Mounting Locations 8DE7AE3D-8D68-41E0-AC83-E2EEEFA1A494
MrFenderpicks
Ivan
Houston, TX
2020 Rubicon
Power Stop Power Stop Part #: BH00147
Power Stop
They are about 1.5-2 inches long then factory. Did give better pedal feel over stock.
Nice, do they come with mounting location like stock?
Or ziptie away?
Kevin Mojito
Kevin
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
They are just like factory with brackets. They don't not have the rubber pad clip thing for the abs sensor wire. That was a ziptie.
ChuckS
Chuck
W Yellowstone, MT
2019 JLUR
I have the 2.5 DSCs. When I fully articulate the sway bar links push the reservoir hose. I’m trying to figure out what to do about this. I moved the reservoir up as far as I can and thinking about using a hose clamp to pull the hose even farther out of the way, but I do t know if it’s going to be enough.
Roky
Roky
If you rotate the resi towards the frame you can run the hose up against the frame and up over the coil housing. I zip tied mine too help keep them over. I had to notch my inner fender a little also . I’ve got plenty of room at full stuff.
Jeep Wrangler JL Fox Reservoir Shocks - Front Reservoir Mounting Locations 564A6338-61A8-4229-AF9D-7B7F5651D14B
Jeep Wrangler JL Fox Reservoir Shocks - Front Reservoir Mounting Locations 70691758-8058-413D-8DC7-BB10B4A2B345
Jeep Wrangler JL Fox Reservoir Shocks - Front Reservoir Mounting Locations DDAEAB3D-9C1C-4D80-B958-77250B3EE9A1
ChuckS
Chuck
W Yellowstone, MT
2019 JLUR
I’ll try that. I have a Road Armor skid plate that might make that too tight, but we’ll see. Thanks
RhinoJLU
Ernie
New York
JLU
Where did you get those rubber hose clamps?
ChuckS
Chuck
W Yellowstone, MT
2019 JLUR
They’re just standard hose clamps, you can get them at any hardware store or auto parts store. I used a cert nut to attach it to the fender liner so I can remove the fender liner easily if needs be.
RhinoJLU
Ernie
New York
JLU
Very clever. Never seen those clamps before with the rubber inside. I may use this in my set up. Unfortunately I don’t think I’ll be replying to this thread any time soon. Ordered my shocks on Presidents’ Day and aren’t expected to ship until April.
Kgc
K
Mesa
2020 Jeep Gladiator
@RhinoJLU - I know this thread is over a year old but I'm curious what you ended up doing? I am looking at installing a similar frame chop bumper.... Thanks
