Four Plus One Tires
Kysport
Louisville
2018 Wrangler JLU Sahara
I am considering replacing the stock Bridgestone All Terrain tires with a new set of Michelin All Season tires. I would keep the new tires the same size as Stock Spare. My question is, if I did need to use the AT tire if I had a flat, would it be OK to use it with the All Season tires. I have a Sahara with the Anti-Slip Differential. Thanks.
Shooting or Jeeping
2020 JLUR, 2019 RAV4
If your question is “can you use an AT if you have a flat and it doesn’t match the all seasons?” - the key is really size. If they arent the same diameter- you have issues. But if the grip/tread is different, there won’t be any issues short term on sure ground. Just like any other spares, it wouldn’t be a good idea to just leave it that way.
Kysport
Kysport
Louisville
Yes. All five tires would be the same size, just the spare would have a different tread pattern and road contact points. Thanks.
