Found Something New... optional Tailgate Reinforcement has flag / antenna mounting hole
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
I believe that a larger wheel and less sidewall is what holds your bead, not wheel width. It’s a wheel-to-tire diameter ratio issue. A 20” wheel with a 35” tire will hold bead better than a 17” wheel with 35” tire, at the same PSI.
That's not how it works at all. The less sidewall you have the less flexibility it has and the easier it is to unseat the bead.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Good copy. I will research further.
Durango
Central California
2020 Jeep Wrangler Rubicon Unlimited, 2019 Ram 1500 Quadcab 4X4, 2018 Challenger Hellcat, 2018 Charger SRT, 2018 American Dream, 2017 Ram 1500 Reg Cab 4X4, 2020 Redwood 3951MB, 2019 Mercedes 4WD Van
I used to air down to 6 psi the tires on my 8K lb 4WD van before wheeling out in the sand, and the wheels were wider than recommended by the tire mfr. They were low-profile tires (not tall sidewalls) by today's standards - and I never had one de-bead. I did however air back up as soon as I got back on pavement - I don't know if it's true, but was told running that low a pressure on pavement where the tires would not be able to "slip" like they do on sand, would surely cause them to de-bead.
Grateful1
Grateful
Guntersville, AL
2018 JLU Sahara 1998 TJ Sport 2011 Extreme Camper
HR Manager
Was out looking at the back of the 2020 JLUR this morning, and saw something I hadn't realized was on the Jeep. Seems the optional Tailgate Reinforcement has a hole just right (and intended I'm sure) for a flag pole/antenna for off-roading - neat! And (this one was more obvious) the third tail light mounting can actually be moved up (or down) in case you get a larger diameter spare tire - neat.
Makes me wonder what else I haven't found yet!
If I understand your post. You are saying the Mopar Tailgate Reinforcement has the holder. Is that correct? Do you have pictures?
Durango
Central California
Yes, that's where the flag mounting hole is. Sorry - no pics yet (not with Jeep now).
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
I ran 315's on my stock wheels with spacers on my JK for several thousand miles including many Moab trips often airing down to 12psi for trails. Never had any issues. Now I run 315's on my stock wheels on my JL.......*knocks on wood* haven't ever had an issue.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
And you never will.
