ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
The best-selling Oculus™ Bi-LED Headlamp system by ORACLE Lighting is now available with a heated lens function for the coldest of environments. Driving in frigid conditions can be unsafe when snow and ice adhere to the lens of the headlight, blocking vital light output. Equip your Jeep Wrangler JL or Gladiator JT with the most advanced LED heated headlight to provide precision lighting and prevent any snow or ice accumulation. This de-icing feature on our heated Jeep headlight eliminates the worry of poor lighting performance and allows for the best functioning illumination when it matters most.
Featuring advanced LED projection with 5,200 Lumens of high-quality illumination, the heated Jeep headlight offers enhanced driver visibility in all weather conditions. The LED light source has lower power demands compared to the factory lamps while providing more light output.
Heater Function:
The design is 100% plug-and-play, with no additional wiring required for the heating element. The heating function automatically activates when the headlight is on and the ambient temperature approaches freezing. An amber LED status light illuminates when the heating function is active, and temperature sensors are integrated into the lights to regulate the heat for peak performance. When the front lens cover is heated to the optimal temperature, the heating function automatically shuts off and will cycle back to active mode when the temperature drops again.
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. No additional wiring is needed for the heater function. Halo DRL features over 200 bright white LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. Complete headlight replacement, better light focus than a simple bulb upgrade. Installation is simplified by a Plug & Play wiring harness which plugs into the factory connector. Package includes a tool for easy beam angle adjustability for proper light focus on lifted Jeeps.
Safety:
Light focus is very important for not only driver safety but others on the road who can potentially have their vision obstructed by glare. This is especially significant on lifted vehicles where the light source is raised and in a position to interfere with the field of vision of other drivers. These new Oculus headlights feature a very sharp cut-off line and focus light with precision specifically to avoid such issues.
Reliability:
It is undeniably important to implement proper thermal management tools for high-performance LEDs to operate with reliability in various environments. Oculus utilizes both active and passive cooling methods to sustain low LED temperatures. Remote mounted heat sinks and an internal cooling fan work in conjunction to ensure proper temperature control and longevity of the LEDs.
We are offering an exclusive pre-order discount on the Heated Oculus in both JLWranglerForums and JTGladiatorForums until 11/30. This discount will not last long so grab yours now if you want in! It's easy to get in on this:
  1. Visit the product page for more information and resources.
  2. In the checkout section, add the discount code exactly as you see here> HEATEDOCULUS
  3. This will apply 15% off the retail price listed. No other codes are applicable with this product.
Screenshot below of checkout:
GET YOUR SPOT NOW!
Normal Price: $695.95
Group Buy Price: $591.56
Please note that the initial estimated ship date is currently November 30th and is subject to change with notice.
Group buy code active for until 11/30. Tentative ship date is said date and is subject to change. Must enter code for group buy discount. Only these lights eligible for discount, not applicable for other products. No additional offers are eligible for this group buy. Free shipping offer is applicable to the continental US only.
ORACLElights
ORACLElights
Metairie, LA
sentience
Maryland
2021 JLU Sahara 4xe, 2019 RAV4 Hybrid
[email protected]
No plans for that at this time :)
I'd also like to express interest in this. Would be nice to have something that could be attached to any 9" round light - I've seen setups which use additional 9" lights for flood and other applications.
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
We're in! Looking forward to them!
ML7
Frisco, CO.
2020 Wrangler JL Rubicon
The only thing better would be to make the headlight able to switch to amber when it sensed there was fog, snow, or dust in the road (a switch would probably be just as cool) so then it would be the absolute safest possible light ever.
HuskerJL
Gretna, NE
2020 Wrangler Unlimited Rubicon 2.0T - Black
My daughter has a JL Sport without factory LED headlights, would these work on her Jeep?
ORACLElights
ORACLElights
Metairie, LA
Very interested.
Where are these made?
Sorry, missed your message. These were engineered in the USA and manufactured with a partner overseas. I'm not sure the exact location off the top of my head; let me see if I can find out for you.
will code this work on the regular lights?
Sorry, missed your message. The code is only applicable for the new version of the light. If you want to purchase other products, you can use the forum code forum10 instead.
Hi Chris, yes, these will work with her Jeep!
-Rachel
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
What affect will the heating element have on the plastic lens over time? Will they turn yellow quicker?
gridsquares
Denver
2018 JLU Rubicon
Looking forward to putting these through their paces this Colorado winter. Is there a warranty?
ORACLElights
ORACLElights
Metairie, LA
The heating element will only turn on in freezing temps so no it will not cause yellowing.
ORACLElights
ORACLElights
Metairie, LA
Hello, this item has a 2 year warranty.
-Missy
Next Venture Motorsports
