For Those Who Change Their Own Oil
MonLee
Stan
NJ
2021 2 Door Sport S
I prefer to drain my oil into one of these, it's amazing how much oil they can absorb.
PBosch
Austin TX
2021 Rubicon XR
and here I was hesitant to post, I thought I was the only one.
Highly illegal and also costly to the car wash operator you a screwing over, not to mention the planet. Your grand kids can thank you later.
mgroeger
Hurricane, UT
2018 JLUR, 2020 Acura RDX A-Spec
Ummmm... pretty sure they were joking just like I don't change my oil at Whole Foods.
Ilya
Ilya
Ontario Canada
Jeep 2019 sport 2 door 6MT
Use Femco drain valve and pour the used oil directly in to its own, now empty container. Used oil bring to local waste disposal center.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
what do you do for the first oil change then? You won’t have an empty container.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
If you save the receipt and clean the outside of the jug really well, you can "return" it.
I bought a jug of Mobile 1 at Walmart once and I cracked it open only to find the seal was missing and the oil was used. If I ever find out who did that I'll make them drink it.
Now I crack the jug and check the seal.
We can't hurt the planet. Eventually it'll get tired of our bullshit and kill us all. It'll be fine until the sun expands and it begin orbiting inside the sun.
rickinAZ
Rick
Phoenix
2021 Rubicon Diesel
If you install a Fumoto valve all the other stuff becomes almost inconsequential. You could literally drain your oil into 12oz soda cans without spilling a drop.
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1987 YJ, 1998 TJ
Have a buddy who says "pour that back in the ground...that's where it came from".
brennaman
Phil
MO
2009 WK 2014 JK, 2021 JLR snazzberry
damn near retired
One autozone I went to in Scottsdale AZ wouldn't take my ATF or gear oil. But that was years ago. I later learned not to say what kind of used oil I'm dropping off. If they don't ask then I wont tell
The auto parts stores I go go also only takes motor oil. ATF and coolant I have to take to a transmission shop.
brennaman
Phil
MO
damn near retired
I go over to my local Whole Foods and pull up to one of the grassy islands in the parking lot where they have a small garden set up. I then rev my engine for a good 15 minutes to get the oil nice and viscous and then CAREFULLY (since it's hot... safety first) crawl under the Jeep and remove the plug.
While it's draining I crack open a nice cold Coors Lite and watch the horrified look on all the hippy, commie, liberal, tree hugger's faces. Once I'm done with the second beer I go under and put the plug back in and put my attention to the the oil filter. By this time I'm typically a little dirty and getting hungry from the beer in me so I take a break and grab something from the deli and a couple of paper towels. Another beer and pastrami on rye later and I'm back at the oil change and it's time to remove the filter.
Typically I will take the filter out and hang it from one of their bee hives they have in the garden as I find it keeps the wasps away from the hive.
Once that is done I will put the new filter in, fill er up with 5 QUARTS (not 6!!!!) and toss the oil jug in the trash bin and away I go.
It's Coors light, not Coors lite. Are you some kinda redneck? :CWL:
Merc
Carlos
South Pasadena
2021 2 door 6mt Willys; 2013 Subaru Crosstrek
I use a Fumoto valve in all of my vehicles. It vastly simplifies oil changes.
For gas engines that take 5 quarts or less I hook up a hose to the valve and drain directly into an empty oil jug. Zero mess that way.
For my diesels that take more to fill, I drain into a big catch can and then fill jugs from there.
what specific size Fumoto valve works for the Wrangle?
PSC Motorsports
