Kyanche
The 3.6s I had prior (JK and chrysler 300) were great, but also pretty noisy. I've never had an issue with them. Fingers crossed that my JL's v6 is the same!
Jmonroe
Jay
2020 JLUR and a '99 Camaro SS convertible I bought new
The engine typically isn't the weak link, given proper maintenance. Keeping the thousand computers, sensors, interface connectors and electronic nannys all happy... These days it's one of those that will be the show stopper.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Good to know that the high RPM powerband is actually good for the motor.
mwilk012
Service
Interesting stuff. It's cool to hear from one of the engineers responsible for the design. I'd love to ask him why they didn't make a stroker version of the pentastar to more suit our jeep needs (longer stroke to provide more off-idle torque at the sacrifice of high redline that we don't need anyway).
Cost, I'm sure. Narrow applicability, little upside.
PavementWarrior
CA
2018 2 door JL
the older lower compression 3.6 no doubt last longer than the "ole pingy" high compression version in the JL.
Ole pingy you can count on to not make it that long, Fiat unleashed!
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
Cool! A few points:
3) the engineer says turn off ESS, exactly what many of us have suspected from Day1; all those starts having to rebuild oil pressure each time just can't be good
I watched the video and did not hear that. Was it said somewhere else?
Compression-Ignition
Roy
Montana
I didn't watch the whole video, but I did see the crank and rod bearings and they look absolutely amazing compared to some BMW engines with 1/5th the miles. Seems like there's no reason anybody with a Pentastar-powered JL should be worried about the engine longevity so long as they change the oil on schedule.
I'll stick to the factory recommended weight and keep an eye on revs to keep them closer to 2k. I usually do that anyway just based on drivability.
Glad to hear running it up in the rev range is good for it - I do that for fun anyway. Disappointed to hear about the ESS - that will only add more fuel to the rabid anti-ESS crowd.
Generally sounds like an excellent engine, but also note in order to get this high of mileage you're gonna be doing a LOT of long highway stints, so those doing shorter trips in town or having longer periods of time between startups could see more wear. I'm impressed and glad my instincts to trust FCA on the Pentastar seem right. Hope the 2.0t is just as durable.
LOL! Why do you care if they don't like ESS? Rabid? [chuckling]
To me the only major flaw to that system is forcing people to turn it off every time they get in their rig. We bought the little device that let's the vehicle remember the last setting and stay there.
When a system causes people so much grief it's kinda easy to see why some people are perturbed by it, for most of us anyway.
beaups
Sean
Ohio
2020 JL
It's not a flaw, it's EPA nonsense. If the disable button is "latching" - e.g. still disabled after subsequent starts, the MFR can't use the feature in their EPA claims. There were some documents flying around on one of the other forums, but that's the gist of it.
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
Here is an interesting comment from a guy who claims to be (and from other posts appears to be accepted as) a former Chrysler engineer who participated in the development of the Pentastar. His username on Bitog is Oil_Udder.
¨Nice! As an former Pentastar design engineer I am slightly bias but the engine is really high quality. Few points from the development using tens of millions of dollars in analysis and testing regarding the oil and durability.....
The lighter oil was chosen mostly for fuel economy BUT engineering is the science of compromise. You help one thing but hurt another.
A thicker oil will reduce timing chain and tensioner wear because the center timing chain idler doesn't go fully hydrodynamic till about 1650rpm on 5w-20. So, a thicker oil will lower that number slightly and with general loads/speeds the engine spends a lot of time around 1500-1750 rpm with the 8 speed. So thicker oil is a win there. Additionally, the earlier engines had what was called the "McDonald's Arches" in the idler bearing which was intended in making a more uniform distribution but in actuality acted as a knife edge. This design was changed around 2014 to a smooth bearing. So overall timing chain issues will likely follow the 2011-2014 engine years more than 2014+.
Where you lose.... The head is very complicated with a Type II valve train. Meaning lots of things to pressurize and pump up at start up. A thicker oil didn't do so well here (on long sit times +cold start) and contributed to a overall increased engine wear especially in the head and cam bearings.
Last point. This engine needs occasional WOT runs if you want it to last. Granny cycling is bad for it. So bad for it we actually created a new granny cycle test during the cylinder #3 misfire issue. The highest wear is in the valve guides, because of tight valve stem seals (for emissions, reduce oil burn). They basically dry out. When you go WOT/high rpm/load you get some fresh oil in there and this keeps the wear down. Thicker oil might not help this condition but we also change the valves/guides/seals in 2014+. Not sure the impact.
Cheers!
PS. Turn off stop start and do not run e85 if you are concerned about engine wear. Eats the engine alive.¨
Curious as to why he says E85 is bad for the 3.6l. I understand its not flex fuel ready from the factory (maybe that's what he is getting at?) but a cracked PCM can fix that. Or it could just be a pre JL post.
DanW
It strips oil film from cylinder walls and probably other parts, as well.
rubileon
Water over dirt planet
JLUR RHD 3.6
https://www.thedrive.com/news/34672...s-chrysler-pentastar-v6-is-after-626000-miles
Check Out How Surprisingly Durable This Chrysler Pentastar V6 Is After 626,000 Miles
See how important maintenance really is.
When you think of reliable engines, something with small displacement, four cylinders, and produced by a foreign automaker probably comes to mind. Hell, just about anything would ring a bell for me before a V6 Chrysler engine. But, as one mechanic who tore down a 626,000-mile Pentastar 3.6-liter will show you, it's (almost) always the ones you least expect.
It all starts with the once-beating heart of a 2014 Ram Promaster. The cargo van—which has enough miles on the odometer to account for at least one round trip to Earth's moon and back—finally bit the dust after a long six years on the road. During that time, the Promaster accumulated roughly 285 miles per day of travels until the six-cylinder powerplant finally experienced a failure that warranted an engine-out service.
According to the owner's YouTube video, the van began running rough and throwing codes related to engine timing. When he pulled the engine, he decided to dig a bit deeper into the failure and determine how the motor held up during its long life. The result is nothing short of surprising.
After a bit of investigation, the owner discovered that the failure was indeed related to the Pentastar's timing. The plastic chain guides broke down over time and the tensioners had outlived their service life. As a result, the motor appeared to have jumped timing.
But that appears to have been the only large failure that occurred. The oil pump was still in excellent condition, the cylinder walls still showed the factory crosshatching and even the rod bearings appeared to have some life left before wearing though the outer-most layer of alloy. Still, the owner claimed that the Pentastar didn't burn oil and ran smooth until the day it, well, didn't.
So what's the owner's secret? As you may have guessed: maintenance. He changed the vehicle's oil every 8,000 miles (though he did admit going over on some rare circumstances) using only Valvoline or Mobil1 lubricants.
But perhaps even more important, the longevity speaks to the reliability of some modern engines, especially one which Chrysler says has the "hallmarks of an enduring icon"—meaning it probably won't be going anywhere anytime soon.
As controversial as the platform may be, the Pentastar is immensely popular within Chrysler's lineup. With more than 10 million units built since the motor's introduction in 2011 between Fiat Chrysler's Trenton South, Saltillo South and Mack Engine plants, the Pentastar has found life in 22 different vehicles—whether it be in 3.0-liter, 3.2-liter, or 3.6-liter configurations (the last being the most widely used). Even today, you can buy a brand new Chrysler 300, Chrysler Pacifica, Jeep Gladiator, Jeep Grand Cherokee, Ram 1500, or many other FCA vehicles with one of these bad boys under the hood.
If you paid for the whole car, you might as well use the whole car—especially if it's going to last long enough to take you around the entire globe 25 times.
I'd like to see the 2L turbo do that
rubileon
JLUR RHD 3.6
As for ESS, I like it in predictable traffic like at lights but if I know I'll be pulling off soon, I turn it off (if I have to stand on the brakes). I do the same when I've floored it and come to a sudden stop... the engine needs to cool down and the coolant pump doesn't work if the engine if off.
Someone asked how PUG will compare, I think like all modern revisions aimed at making accountants happy, will fair worse than the one the original.
Dkretden
Denver, CO
2020 JLUR 3.6L
It’s not “EPA nonsense”...... it’s FCA nonsense. FCA had a choice to make. One choice burdened their customers by not making the switch latching. The other choice burdened Their shareholders by having the company pay a slightly higher cash penalty for not meeting some level of CAFE standards. FCA designed a horrific implementation of the ESS system and then chose to burden their customers with it to save their shareholders a couple of bucks. That is FCA nonsense.
of Course, the obvious choice would have been to build a latching switch (Or better yet, build the damn jeep with an option to not have any of the ess crap) and then simply raise the price of the vehicle by some surcharge amount for those who didn’t want the ess craptastic system. Shareholders pay nothing and the fines are offset by the increase in price For those who don’t want ess.
