Crusifix
- Jeff
- Mar 8, 2019
- West Virginia
- 2019 JLU Rubicon 2.0T Hurricane
One of their design engineers really missed on that one.
How did we go from you rigging this to work to others saying there is not a fix possible with the current design?I ended up placing a small pice of weather stripping (not a permanent fix) to the top of the BSM where the screw is and it works! Now it is pointed level and can "see" the area where cars are. Oracle needs to do something like bkgray115 suggested with a different holder or just a spacer that fits just underneath the plastic area by the screw to fix this problem. Until Oracle provides a fix i'll look for a little more permanent one.
For me it was looking at the mounting area, unless you cut up the inside of the light you not get hardly any movement the main supporting bracket locks everything in and then the mounting bracket goes on that. I was not willing to cut up the light so I couldn't return if it didn't help enough. Mine are getting returned in the morning.How did we go from you rigging this to work to others saying there is not a fix possible with the current design?
Ok you can also add me to the list of BSM not working. It’s such a shame. The lights are extremely clean and so is the mechanism inside the light. I’m really disappointed.I bought and installed these tonight. Will test tomorrow to ensure the BSM works correctly. I wish I had read through this thread before purchasing. Love the way these look but not at the expense of a safety feature not working accurately.
I don't see how anyones BSM works at this point honestlyOk you can also add me to the list of BSM not working. It’s such a shame. The lights are extremely clean and so is the mechanism inside the light. I’m really disappointed.
I'm guessing if it were they would've done itI don't see any way to fix this and still have them be flush. Glad I don't have BSM.
Do you have a pic? as the top bracket sits down tight on the bracket holding the BSM unit I didn't see any room to adjust.My BSM works. I described it a few pages back. I added a piece of weather stripping to the top of the BSM to point it down a little. Mine works. The BSM is currently aligned with the vertical plane of the light/jeep and pointed too high. Oracle can fix this.
Mine is hit or miss with larger vehicles as well. Not picking up cars at all thought. Where exactly do I put the weather stripping?My BSM works. I described it a few pages back. I added a piece of weather stripping to the top of the BSM to point it down a little. Mine works. The BSM is currently aligned with the vertical plane of the light/jeep and pointed too high. Oracle can fix this.
Do you happen to know the size/thickness of the stripping?I removed the BSM and placed a small piece of weather stripping between the bracket and the light housing just below the screw hole on the top to point it lower. I don’t have a pic as they are installed.
