Yorkie3621
thank you for this. I have installed flush mounting LED Oracle lights and kee getting the rear bulb out warning. I went through this process and they were all already showing as active so I toggled to deactivate and then back to active but no change. Any advice?I cant elaborate on which is better, I've not tried Tazer. I chose OBDjscan because I already had experience using a bluetooth code reader with Torque (app used with smart phones to display the code readers output). Also the price is less, OBDjscan was $22 and code reader is less than $50 bypass cable was $35 I think. (I dedicated the code reader to my Wrangler) I have the bypass cable and an extension cable & I leave the code reader installed full time.
Edit: My Wrangler is a Sport S this may not be the same with other trims.
After connecting to the vehicle this is the first screen, tap on Adaptation:
On second screen tap LED lights settings:
On the 3rd screen change these 4 settings:
Tap each one at a time and select the drop down triangle tap active and ok:
When you return to this screen tap GO :
the Jeep came with les rear lights but not with the full led package, just rear led lights. Iāve had aftermarket led lights for the past two years without any modification or problems, just plug and play. These are the only ones giving me a problem.
Thanks for your help
