Flush and Refill Differential Fluid after offroad
Lehman26
Ryan
York PA
2018 Wrangler Unlimited Sahara JL
Question for everyone. Just took the Jeep to AOAA in PA and took it through some fairly deep water/mud holes. My question is at what depth of water will it allow the water in to contaminate the diff fluid. I have a stock Sahara and am thinking at most the level was up to the factory side steps. Just looking to see if I should be looking into switch out the fluid or its fine.
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Did you go deep enough you were above the breather tubes?
Lehman26
Lehman26
Ryan
York PA
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
I guess that's the answer I'm trying to find, where exactly is the tube located?
In a Rubi it comes off the axle and up into the chassis. Presume a Sahara does similar. If you climb under you can trace it along.
Lehman26
Lehman26
Ryan
York PA
Ok yes I saw the line coming off of it now and it's exactly like the rubicons. I'm thinking that I wasnt that deep in the water . Is there a simple way to just check the fluid without drawing it, if I remove the fill plug will fluid come out or is the fill level under that
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Fill level is under the fill plug. I seriously doubt you will have water in the diffs.
But if you really want to check since oil is heavier than the water so the water rises if you pull the top plug and use some sort of q-tip you can skim and see if water or oil is at the top.
Lehman26
Lehman26
Ryan
York PA
Awesome man , really appreciate the help! Thanks
D&C Designs
