Floor mats for the 4xE
Skades 89
Cambridge,WI
Jeep Wrangler Rubicon 4xe
My dealership had them in stock when I took delivery in September. Love them.
Jeep Wrangler JL Floor mats for the 4xE DDFF4656-AA4D-4F12-80F2-057F226429E4
Jeep Wrangler JL Floor mats for the 4xE BC493C55-366E-4021-970D-330286B0B58C
docmac
Doc
Clarksville, TN
2021 JLU 4xe
Just put in the Weather Tech floor mats and they fitted perfectly. The only issue is I cant decide if I want to cut the cargo area mat to allow for the hook system to pop through.
If you cut those ports, let us know how that works out. Pictures would be great, too.
Jfk3674
Atlanta GA
2021 Jeep Wrangler 4XE Rubicon
Im leaning more and more to just cut a slight slit where the chrome hook is to push through.
docmac
Doc
Clarksville, TN
2021 JLU 4xe
I can see that. I just got my Weathertech yesterday and am letting it uncurl to lie flat before I install it, but that sounds like a good option to start with.
Sam_Ca
Sam
Canada
Wrangler
My dealer gave us a set of mats and we had to install them ourselves. They were the standard JL set and didn't fit the rear seat so we had to trim them. Make sure you get the 4xe specific set and you will be fine.
To clarify....the fronts fit fine. The rears don't fit. If you happen to get a set of standard JL mats for a bargain price then you can make them work. Best way is to remove the plastic housing around the battery so you can trim the rear mats so they extend under there a little further. Then re-install the plastic housings and the mats will look like they fit perfectly. Well, except for the rearmost retention pin. That wasn't in the correct spot so I had to cut a new hole. It looks a little rough but in the whole scope of things it works okay. These mats were free to me so I made them work. 🤫
Same boat, how difficult it to remove the battery guard ? Can I just keep it ?
Equitasforall
Virginia or Tennessee if in the US
2021 Rubicon 4xe
I could tell you, but then....
My weathertech ended up fitting beautifully… both rows and in the cargo area. Glad I made the choice.
michail
2021 Sahara 4xe
If I get the armorlite floor anyone is welcome to make me an offer for my OEM 4xe mats for a Florida pickup. :)
Rrod8
Ray
4xe wrangler high altitude
hey Do you have the OEM weather mats? If so depending where in Florida I could possibly take off your hands.
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
I've been looking at Weathertech also, it appears they have two versions: 'Floor Liner' and 'Floor Liner HP'. The HP ones seem to have better coverage and only cost a little more. The pictures seem to show that they cover up onto the interior door sill trim - any concerns with that area catching on boots or rolling up after a while?
Thanks -
LF
Equitasforall
2021 Rubicon 4xe
Thanks -
LF
Not sure on that. I went with the standard floor liners as I’ve used them before on other vehicles. They’ve worn well, fit great, and never had issues with rolling or catching on tread. They’re pretty rigid unlike other brands I’ve seen.
Left Field
Tim
Western WA
My past experience with Weathertech fit and quality has been good; think I'll pull the trigger on a set. Thanks for your first hand assessment!
Left Field
Tim
Western WA
Follow-up:
Received my Weathertech HP all weather floor mats yesterday and installed them. They are firm (not floppy) and fit perfectly, with good perimeter edge height and a tight fit along the door sill, which is what I was looking for as it keeps mud/slush/debris from falling in the gap. Snap-down floor pin connections are closed on top of the mats so no leakage issues.
