Torero
I wouldn’t use 4. Work one axle at a time.Thanks, suspension is my first use for these (and oil change, tire rotation).
Some reviewer comments on those 30 stabilizers make me a bit skittish. Are those definitely legit to use as jack stands?
Next question - should I plan on 4 stands to have everything up and level for the suspension work? Or is it fine to do front end then back end with just two stands?
As for the Jack stands, any will be wobbly fully extended. You don’t want to do that. You lift, take tire off and set the jack stands in position but much lower. No need to keep the Jeep that high. Lower is safer. lower the jack to have the frame meet the jack stand. You only need enough height to let suspension fully drop. You don’t need to clear the tire at this stage.
