Flipped Fox Steering Dampener hits tie rod?
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
anyone else have this issue?
I installed a synergy SD relocation kit and my fox SD just barely hits the tie rod at full right turn. I’m assuming that’s just how it’s going a be?
word302
Oregon
JLU
I had the same issue. I bought a Metalcloak axle bracket and made a couple modifications to get it to clear.
Jeepjunkie
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
Thanks, I’ll look into Metalcloak!
quietpeen
Chambersburg, PA
2019 JLUR
I had the same issue and bought the steering smarts bracket to eliminate it, but now the bolt on the bracket hits the tie rod. I do have a new synergy tie rod to install which should eliminate all rubbing but I’m waiting for a new fox tie rod clamp since the synergy tie rod is only 1-1/2” diameter.
Jeepjunkie
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
I just ordered the metalcloak axle bracket, as word302 suggested. It looks like it lifts the SD up, and away from the tie rod. I also like that the “eye” section through bolt of the SD is horizontal with the metalcloak bracket, and not vertical like my current system.
quietpeen
Chambersburg, PA
2019 JLUR
that should work great for you.
Roky
Roky
What modifications please......:movember:...and could you help a brother out with a pic?
