MaxD
- Rob
- Jun 8, 2020
- Eagleville TN
- 2019 Wrangler Sport S
- Occupation
- Maintenance Manager
I've learned a lot on this forum and have used a lot of that knowledge to get mine the way I want it (LED upgrade, Halos, Jscan, Flat tow harness install etc.)
I am now turning to the members here to see if anybody has a work around for this because the dealer doesn't have a clue and Jeep/Mopar Care can't help anybody past "talk to your dealer"
Factory Tow package installed.
Towed Vehicle Harness 82215382AB installed
I use a cargo tray with a large diamond plate toolbox to haul firewood and propane tanks (that blocks the JL tail lights)
I tow this behind my Motorhome.
The towing package works the lights perfectly on it's own
The 82215382AB harness works the tail lights on the JL perfectly
While hooked up to the motorhome, I have NO tail lights, stop or turn through the receiver hitch towing plug to my toolbox (equipped with LED markers, tail lights and an LED truck tail gate strip)
I know the harness uses relays to drop off any "feedback" that could harm the JL electronics and I'm sure the power to the tow package module has the power cut via those relays.
Anybody experience this?
Anybody have schematics of both harnesses to determine if I can supply power to the tow package module using the 12v from the motor home via the 82215382AB harness?
Will this cause any electronics issues?
Thank You for any help I can get, I would hate to burn down my JLU with 98 miles on it.
