Yes. It works great. I took it off for the steering box change, but, I've been told it wouldn't have been a problem if I set it back to stock on the exchange ECU.Is anyone running the Flashpaq on their 2.0 turbo? Also, since it requires a PCM swap, does this limit any software updates that the dealer can perform?
Did you have to swap the PCM back before the steering box, or just removed the flashpaq but left the PCM?Yes. It works great. I took it off for the steering box change, but, I've been told it wouldn't have been a problem if I set it back to stock on the exchange ECU.
I swapped the PCM (just to be 100% sure) . I was told that I didn't need to. The new steering gear works great. The Flashpaq is great, I had no idea it would be such an improvement to an already fun vehicle.Did you have to swap the PCM back before the steering box, or just removed the flashpaq but left the PCM?
Flashpaq does a swap. I was just slow in returning my locked origional PCM.Where did you get an extra PCM from?
