Flashing rear locker light... bad hall effect sensor? Jeep won't warranty, part not available for puchase!
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
Since the sensor doesn't have a programmable chip in it, what's this calibration you're talking about?
fixbroke
fixbroke
2020 JTR
It does, if you look at my pics from the disassembled sensor - the hall chip itself is probably the programmable element. I'm pretty sure the third, unused pin in the connector is used for programming.
Lou_JLU
Louis
Adirondacks
2018 JL Wrangler Sahara, 2019 JL Wrangler Sahara
I'm thinking: Pin 1: Power in, Pin 2: Pwr Return, Pin 3: Sensor signal Out.
Gorilla57
Chandler AZ
2019 JLUR Mojito
Not sure why the sensor has to be calibrated. 2 different people on here have swapped out their malfunctioning sensors with new ones and it worked just fine.
fixbroke
fixbroke
2020 JTR
There are three pins on the sensor, but only the two outer pins are connected to the Jeep wiring harness. It works as a current limiting device. Voltage is supplied to the sensor, and depending on the magnetic flux it senses, a variable current is output (amperes, not volts).
The fact that they bothered adding the third pin to the housing connector means that it must be used somewhere in the manufacturing process, probably a calibration step.
fixbroke
fixbroke
2020 JTR
I got my sensor back from my friend after zapping it, but the patient wasn't revived by the defibrillation. The continuity between pins is gone (good), and there is still a connection between the pins and the hall chip (good), but I'm still getting the dash error (bad).
I guess I'm getting a Z Locker OEM.
2Wheel-Lee
Lee
Orange County, CA
On a good note, the Z Automotive Z Locker OEM works as advertised and I am not having any issues with it.
Jeep Wrangler JL Flashing rear locker light... bad hall effect sensor? Jeep won't warranty, part not available for puchase! 1597141980239
Z Locker OEM
I'm tempted to buy one of those to keep in my tool bag, in case I'm on a long trip, and one of my locker sensor dies.
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
JL Wrangler Rubicon - Hella Yella - 2.2 Diesel
That's exactly what I did... despite the rather high price of this cable.
Which is still incredible, absolutely not normal, for a new car (for mine with few kilometers) and at this price!
2Wheel-Lee
Lee
Orange County, CA
Figures...I drove my JL this morning around town, and all was fine. I drove it this afternoon, and the rear locker light was flashing from the moment I started the engine. I pulled over and did some tight turns, and the locker was not engaged. I put it in 4lo and engaged the locker, and it engaged (light stopped flashing and stayed on). I tried to disengage it and it wouldn't disengage, but the light was flashing. I put it back in 2hi and started driving with it engaged. At the next stop light, I shut off the engine. The locker disengaged (I made a turn at the light), but the light was still flashing. Sigh...looks like I'll be buying two of the Z Lockers. One for the rear now, and one for the front when/if it needs it.
fixbroke
fixbroke
2020 JTR
Sounds exactly like my failure. You probably have oil in your sensor. My condolences and welcome to the club!
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
I read that only one cable is required. Put it on the back. Can anyone confirm that?
fixbroke
fixbroke
2020 JTR
You need one for each failed sensor. However, the front should take a lot more time before it fails since the front axle is used so infrequently and at lower speeds. It may even last the life of the vehicle. Personally, I wouldn't bother carrying a spare Z locker for the front axle.
I also potted my front sensor with RTV to keep it from failing. I'll post a how-to some time soon showing how I did it.
SwissSteph
Steph
Switzerland
www.swissjeepjl.com
Thank you for your response
BSw
Bert
Sacramento, CA
2018 JLUR - 2015 Ford Mustang - 2018 Volvo S90
Had the same issue, installed the Zautomotive cable today and issue is gone. If you're still in warranty and didn't regear the dealer will swap your axle, otherwise the cable is the best fix until a new sensor becomes available
