Flashcal 2.0 Now Available - 1st Glance for JL Forum Members
Superchips JL
Summit Sponsor (Level 3)
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
We are excited to roll out Flashcal 2.0. New exciting features include Auto Start/Stop disable, Auto Park as a live/running feature, and more! See full details below. We have not made any public announcement yet, but v 2.0 is live for those that may want to update their device. As a heads up, I try to stay frequent here, but want to make sure you get timely replies to questions. In addition to PMs, you can also use [email protected].
Please see hand off doc from R&D - we've been validating these features the past several weeks. Thanks to the many of you that helped us with this effort.
Stay tuned for additional exciting news on a new platform rollout!
Jeep JL Flashcal v2.0 - Feature Update
Running Options Menu
Non-permanent settings that return to stock when the tuner is unplugged and/or the user exits the options menu and/or a key cycle occurs.
Feature: Engine Idle Up
Customer Options:
Range from 700 RPM up to 2000 RPM. Increments of +/- 100 RPM per button press.
What it does:
Once the user selects an RPM value the Flashcal sets and maintains that engine RPM value until the user
exits the menu or unplugs the device.
Feature: Sway Bar Unlock
Customer Options:
Unlock / Exit
What it does:
When the user selects "Unlock" the Flashcal will force the sway bar to disconnect, regardless of drive mode (2H,4H,4L) and hold it in a disconnected state unless the vehicle exceeds 25 MPH or until the user selects Exit or disconnects the Flashcal.
Factory settings allow the driver to disconnect in 4H and 4L drive modes only and will lock it back if the driver exceeds 17 MPH, shifts into Park, and/or switches to 2H drive mode.
Feature: Line Lock
Customer Options:
Lock and Hold / Exit
What it does:
On selection of "Lock and Hold" prompts the driver "To Engage, Firmly Pump Brakes until Hard" for 4 seconds then switches screens to "Line Lock ACTIVE. Press OK to Cancel".
This action will lock the front brakes and hold them locked until the user presses OK on the device or unplugs the Flashcal.
Feature: Rock Crawl Lock
Customer Options:
What it does:
On selection of "Lock and Hold" prompts the driver "To Engage, Firmly Pump Brakes until Hard" for 4 seconds then switches screens to "Rock Lock ACTIVE. Press OK to Cancel".
This action will lock the front and rear brakes and hold them locked until the user presses OK on the device or unplugs the Flashcal.
Feature: Auto Park Disable
Customer Options:
None
What it does:
On the selection of "Auto Park Disable" displays "Auto Park DISABLED. Hold OK to Cancel”.
This will disable the Auto Park feature for the duration of the Key cycle and/or until the Customer presses “OK” on the F5 to cancel.
Vehicle Configuration Menu
Feature: Tire Size
Customer Options:
selection list from 25 inches to 40 inches with .25 inch resolution.
What it does:
Updates the stored tire size in the vehicle which is used to determine Vehicle speed, gas mileage, etc.
Feature: Gear Ratio
Customer Options:
2.73, 3.07, 3.21, 3.55, 3.73, 4.10, 4.56, 4.88, 5.13, 5.38
What it does:
Updates the stored gear ratio in the vehicle which is used to determine Vehicle speed, gas mileage, etc.
Feature: Transfer Case Low Gear Ratio
Customer Options:
list of available standard gear ratio options
What it does:
Feature: TPMS Warning Threshold
Customer Options:
selection list from 22 psi to 56 psi, integer increment resolution.
What it does:
Adjust the Tire Pressure Monitoring System to warn the driver when any of tires drop below the selected psi value.
Feature: TPMS On/Off
Customer Options:
Enable / Disable
What it does:
Disable:
Removes TPMS screen from the Vehicle Info Screens located in the Instrument Cluster Panel.
Removes the Yellow Low Tire Pressure warning light on the Instrument Cluster Panel.
Enable:
Returns all screens and lights related to TPMS back to factory settings.
Feature: Daytime Running Lights
Customer Options:
Always On
Selectable
No DRL
What it does:
This setting makes changes to the way the Light Selection knob works.
Always On:
Even when the knob selection in the OFF position, the DRL remain on while the vehicle is running.
Selectable:
"Stock" setting. DRL off on knob OFF selection. DRL on while the knob is in the running light position. DRL fender lights off Headlights on for knob on Headlight selection.
No DRL:
DRL fender lights remain off regardless of knob selection.
Feature: DRL Location
Customer Options:
No Running Lights
High Beams
Low Beams
Turn Signals
Fog Lights
Fender Lights
What it does:
No Running Lights:
Turns off/ Keep off the JL fender lights regardless of DRL switch selection.
High Beams:
Switches Running lights to the High Beams. Requires user to flash high beam switch to fully enable this feature.
Low Beams:
Switches Running lights to the Low Beams.
Turn Signals:
Switches Running lights to the Amber Turn signals on the fender of the JL.
Fog Lights:
Switches Running lights to the Fog lights.
Fender Lights:
"Stock" JL setting. White Lights on the fender as the Running Lights.
Feature: DRL Dropout
Customer Options:
Enable / Disable
What it does:
This feature is active when the DRL location is stock and ON and the Driver is using their Turn Signal.
Enable DRL Dropout:
When enabled the White fender light turns off for the duration of the turn/Amber signal being active.
Disable DRL Dropout:
When disabled the White and Amber fender lights alternate on/off states for the duration of the turn signal is active.
Feature: Fog Light Dropout
Customer Options:
Enable / Disable
What it does:
This feature is active when the vehicle lights and fog lights are ON.
Enable:
When the High beams are activated the Fog lights turn OFF.
Disable:
When the High beams are activated the Fog lights remain ON.
Feature: Halo Lights
Customer Options:
Enable / Disable
What it does:
Enable:
Turns the headlight Halo lights ON.
Disable:
Turns the headlight Halo lights OFF.
Feature: One Touch Lane Change
Customer Options:
Enable / Disable
What it does:
Changes the turn signal characteristics on a quick touch of the turn signal switch.
Enable:
Will cause the turn signal to flash 3 times automatically.
Disable:
Will cause a quick flash of the turn signal.
Feature: Seat Belt Minder
Customer Options:
Enable / Disable
What it does:
This feature is active while the vehicle is underway and the driver/passenger is unbuckled.
Enable:
The vehicle makes an audible dinging to remind driver to buckle up.
Disable:
The vehicle does not make the audible dinging.
Feature: Travel Link Weather Warnings
Customer Options:
Enable / Disable
What it does:
Enable:
Turns ON SiriusXM Weather pop-ups and SiriusXM Traffic information.
Disable:
Turns OFF SiriusXM Weather pop-ups and SiriusXM Traffic information.
Feature: Splash Screen
Customer Options:
Sport / Sahara / Rubicon
What it does:
Changes the startup splash screen displayed on the Instrument Cluster Panel on vehicle start.
Sport:
Displays the Wrangler splash screen.
Sahara:
Displays the Sahara splash screen.
Rubicon:
Displays the Rubicon splash screen.
Feature: Standard / LED Light
Customer Options:
Front Turn / Tail Lights / CMHSL
What it does:
Front Turn:
Standard: Adjust vehicle configuration for use with standard Front Turn / Fender Lights
LED: Adjust vehicle configuration for use with LED Front Turn / Fender Lights
Tail Lights:
Standard: Adjust vehicle configuration for use with standard Tail Lights
LED: Adjust vehicle configuration for use with LED Tail Lights
CMHSL:
Standard: Adjust vehicle configuration for use with a standard 3rd Brake Light
LED: Adjust vehicle configuration for use with a LED 3rd Brake Light
Feature:
Auto Stop/Start (ESS)
Customer Options:
Enable / Disable
What it does:
Enable:
Returns Auto Start/Stop screen and Hood Ajar warnings to Cluster Panel.
Disable:
Removes Hood Ajar monitoring and Remove Auto Stop/Start Info screen from Instrument Cluster Panel.
* Will cause the “Service Auto Stop-Start system” screen to pop up occasionally as well as the AutoSS service symbol to be displayed above the Fuel Gauge.
Add / Remove Modules Menu
Feature: Auxiliary Switches
Customer Options:
Enable / Disable
What it does:
Enable:
Adds the Auxiliary switch settings screen to the Integrated Center Stack.
* User will need to add the Stock JL Auxiliary switches for this configuration update to work.
Disable:
Removes the Auxiliary switch settings screen from the Integrated Center Stack.
Feature: Towing Package
Customer Options:
Enable / Disable
What it does:
Enable:
Configures the vehicle for trailer tow package.
* May require the user to add trailer wiring harness?
Disable:
Removes the trailer tow package vehicle configuration.
Feature: Blind Spot Detection Add Only
Customer Options:
Enable / Disable
What it does:
Enable:
Configures the vehicle for Blind Spot Detection monitoring.
* Requires user to add blind spot detection mirrors.
Disable:
Removes the blind spot detection vehicle configuration.
Feature: Sway Bar System
Customer Options:
Enable / Disable
What it does:
Enable:
Configures the vehicle for use with the Automatic Sway Bar System.
Disable:
Removes the Automatic Sway Bar System vehicle configuration.
Feature: Cargo Camera
Customer Options:
Enable / Disable
What it does:
Enable:
Configures the vehicle for use with a "Cargo" Camera input/2nd customer mounted camera, adds cargo camera selection to Integrated Center Stack.
* Requires a special harness to connect camera to UConnect system.
Disable:
Removes the Cargo camera selection from vehicle configuration.
Feature: Backup Camera
Customer Options:
Enable / Disable
What it does:
Enable:
Adds Backup Camera Selection Screens/Monitoring to vehicle configuration.
Disable:
Removes the Backup Camera Selection Screens/Monitoring from vehicle configuration.
Feature: Electronic Steering Pump Remove Only
Customer Options:
Enable / Disable
What it does:
Enable:
Adds the Electronic Steering Pump Module to vehicle configuration.
Disable:
Removes the Electronic Steering Pump Module from vehicle configuration.
Feature: Axle Lockers Remove Only
Customer Options:
Front / Rear / Front & Rear
What it does:
Front:
Enable:
Adds the Front Factory Axle and Front Axle Disconnect Module to vehicle configuration.
Disable:
Removes the Front Factory Axle and Front Axle Disconnect Module from vehicle configuration.
Rear:
Enable:
Adds the Rear Factory Axle Module to vehicle configuration.
Disable:
Removes the Rear Factory Axle Module from vehicle configuration.
Front & Rear:
Enable:
Adds the Front & Rear Factory Axle Module to vehicle configuration.
Disable:
Removes the Front & Rear Factory Axle Module from vehicle configuration.
Feature: Factory Fog Lights
Customer Options:
Enable / Disable
What it does:
Enable:
Add the ability to use factory fog lights if they are added after factory build.
Disable:
Removes Fog light use if factory fog lights are deleted.
Service Options Menu: Will be useful for troubleshooting/diagnostics for customers and tech support.
- Module Reset
ABS - Anti-Lock Brake System
BCM - Body Control Module
TPMS - Tire Pressure Monitoring System
IPC - Instrument Panel Cluster
- ABS Initialization - may need to be run multiple times before vehicle accepts new tire/gear size.
Menu System Layout
• Running Options
- Engine Idle
- Sway Bar Unlock
- Line Lock
- Rock Lock
- Auto Park Disable
- Exit
• Vehicle Settings
- Tire Size
- Gear Ratio
- Transfer Case Low Gear Ratio
- TPMS Warning Threshold
- TPMS On/Off
- Daytime Running Lights
- DRL Location
- DRL Dropout
- Fog Light Dropout
- Halo Lights
- One Touch Lane Change
- Seat Belt Minder
- Travel Link Weather Warnings
- Splash Screen
- Standard / LED Light
- Auto Stop/Start
- Exit
• Service Options
- Reset Module
- Exit
• Add / Remove Modules
- Auxiliary Switches
- Towing Package
- Blind Spot Detection
- Sway Bar System
- Cargo Camera
- Backup Camera
- Front Axle Disconnect
- Electronic Steering Pump
- Axle Lockers
- Factory Fog Lights
- Exit
NathanG
Nathan
Tucson AZ
2018 JLU Rubicon
Updated to version 2.0 thru ignition software, didn't see option to disable seat belt chime in the flashpac menu. ALso can you give more info as to ESS disable? it flashes a notice to remove hood switch. How does this new function work?
Dadawada
Barrett
Raleigh, NC
2018 Rubicon Unlimited, 2020 Honda Goldwing Bagger
Network Technology Executive
I thought I had seen, somewhere, on some programmer, the ability to select "Standard" or "LED" headlights also.
I just got my Flashcal to adjust tire size. This seems to work great, though a manual entry would be nice. My tire is 34.41" but the closest is 34.50".
I did see the other features mentioned in this thread present. I disabled Start/Stop. But I did not see an option to select LED headlights. My aftermarket LED bulbs are not working properly. They were not cheap. The high beams will stop working sometimes when I activate the turn signal. Then they will just turn off all together. I'm thinking this is because of a setting to tell the canbus system the lights are LEDs. Is this a feature that will be added?
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
Hi @NathanG - see attached instructions. Hope this helps. Again, we're giving the JL forum guys the first glance and v2.0 is live. We'll be officially "announcing" next week to the mass market. Thanks!
Hellow0rld
Tony
Irvine, CA
2018 JLU
I believe the only options we have right now to change LED is Front Turn, Taillight, and CMH Stop Light. I could not find an option to change the Headlights from halogen to LED.
Dadawada
Barrett
Raleigh, NC
That is correct. Unfortunately the Mopar LEDs and some high end aftermarket will not function correctly unless the setting in the Canbus is correct to tell it to look for LED headlights. At least that is what I'm being told by Mopar. That is why the Mopar LEDs for the Jeep require Dealer install. I'm just the messenger here folks.
Can anyone verify this? On my LEDs, the high beams will sometimes go off. Turning the car off and on and they come back on but may go off again. I'm thinking you have to tell the Jeep somewhere it has LED headlights.
NathanG
Nathan
Tucson AZ
2018 JLU Rubicon
What is this feature actually doing? I dont see how it is any different than simply removing the hood switch. There isnt any difference. Id like the warnning chime and message to stop.
Also there is no seat belt reminder on the menu.
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
Auto S/S feature removes Hood Ajar monitoring and Removes Auto Stop/Start Info screen from Instrument Cluster Panel.
You own a JLU Rubicon correct?
NathanG
Nathan
Tucson AZ
2018 JLU Rubicon
Yes
I own a JLUR. If only one hood switch is re-positioned out of the bracket, we get no hood warning without the flashcal. . Removing the stop start screen screen is of no real benefit. A true disable feature would stop the warning chime/ notification that stop start is disabled, and get rid of the warning symbol above the fuel gauge.
You would be better off not offering this feature than mis-advertising the ability to disable stop start.
mr_chenyang
Taiwan
Jeep Wrangler Rubicon Unlimited JL
Is it supported Canada version JL Rubicon?
MotoMax
Bob
S. Hatteras Island
2018 JLU Rubicon, 2020 Jeep Grandcherokee
Do nothing bum Retired
I saw on Quadratec's site that they advertise the Flashcal as having a "Lockers in 4H" feature for the Rubicon.
I recently checked for updates for my unit. Plugged in I don't see that feature for my Rubicon.
Is it really available or not? Thanks Guys
ashg2000
Ash
Atlanta, GA
Jeep Wrangler Rubicon JLU
Speedometer calibration issues
I have Nitto Ridge Grappler 35 x 12.5 x 17 tires on my jeep rubicon JL and used the Flashcal to change the tiresize to 34.75. The speedometer is consistently off by 5%, Jeep shows driving at 42 miles/hr vs. waze or other speedometer tools at 40 miles/hr. Has anyone else faced this problem and found a fix? I will do hit and trial by lowering the tire size, which might help but it's not the right solution.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Not sure what choices you have on the Flashcal but I have a Tazer JL and am running 315 KO2’s and when I first made my adjustment I measured the tire right at 34” but it was 5 mph off using my GPS speedo app so I kept bumping it up one choice at a time and then checked and finally when it got to 34.49” it was spot on at 75 mph so you may try bumping it up to the next larger size and checking and keep doing that, it worked for me
Edit:
Just reread your post and you said your speedo was showing faster than GPS so if that’s the case go down in tire size, for me the GPS was showing faster than speedo so I went the other way
ashg2000
Ash
Atlanta, GA
Edit:
Thanks...
Finally speedometer is calibrated well. For Nitto Ridge Grappler, 35 x 12.5 x 17 which is 34.76 tire circumference, at 28 psi, 34.25 tire setting gets the correct results.
