[FIXED] Help - I got my rear seat stuck
OldGuyNewJeep
Don
CT
When I flipped the rear seat in my 2dr from folded position to upright, there was a bungee that I didn’t see. Now the seat will not flip back up. The bungee is really stuck - there’s no pulling it out.
Ideas?
Jeep Wrangler JL [FIXED] Help - I got my rear seat stuck FA12FEE1-D1B8-49E7-9C75-4AFCDC1DD5E1
OldGuyNewJeep
OldGuyNewJeep
Don
CT
Cut bungie? Or take seat out to try from other angles
I did cut it, but no use. It’s a thin, flat elastic.
I can’t take the seat out and that is the problem. I can flip the back up and it functions as a seat, but if I try to fold it forward (step 1 for removing it) it’s no good. The latch that holds it to the floor is the one that has a bungee stuck in it.
OldGuyNewJeep
OldGuyNewJeep
Don
CT
Brute force for the win! Grabbed with vice grips and put my weight into it. It ripped apart. Phew!
Jeep Wrangler JL [FIXED] Help - I got my rear seat stuck image
bio86250
Leon
Chicago, IL
2020 JL Willys, 2022 JL Willys Sport
I have the same situation, but mines is the floor liner piece that stuck in the rear seats latch section and I can’t reach them. (not sure if I describe it correctly) Is there other way I can remove the seat in this case?
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
Like they taught us in the Air Force...Beat to fit, Paint to match.
bio86250
Leon
Chicago, IL
Thanks. I did pull the floor liner out, but some of piece still inside the latch, I can’t reach them, that’s why I am asking… Is it possible we unlatch the front latches? (the two that can remove the whole seat)
Bill_P
Bill
Orange Va
That I'm not sure of. Do you have a long pair of needle nose pliers? You might be able to reach in and grab the pieces and pull enough out so you can work with the seat.
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Might try a pry bar under the seat with the latch opened as much as possible. Yet another reason for a 2dr without the rear seat😏
