belfonte
- Jan 8, 2022
- Washington State
- 2021JL Sport Manual 2Dr
Maybe this has been posted before, I don't know. But today I loaded the kids for some outdoor fun only to find that my seat was tight up against the steering wheel and wouldn't budge. We had to cancel the fun, and instead, I spent an hour figuring this stupid thing out. Hope to spare someone else the trouble.
The problem is a small plastic piece that's about an inch long, that has a spring loaded lever inside. It's called the "seat position return".
Here's a link to the TBS report that some other guy posted. It's a known issue. There is one for each seat and it moves along the door-side track. The left and right sides specific and not switchable.
What this thing does is to return the seat to normal functioning after you use the shoulder lever to slide the seat forward for getting in and out of the back seat. Without it, the seat will be stuck in that egress mode and slide back and forth without locking in place, and the pull strap will not work to move the seat back to upright position.
(If the plastic piece breaks with the seat fully forward, it may jam in the tracks and prevent the seat from sliding back at all. Several people have had to get their jeep towed.)
This piece breaks when the seat is slid back and forth roughly, because the plastic housing can't withstand the abrupt action on the metal lever inside it.
The reason it's plastic is because the piece was designed to be installed by snapping into place on a small tang it runs on.
In the picture below you can see the bottom half of the lever that the plastic piece holds. If you push up on it, you can work it backwards along the track and out from under the seat. This is for curiosity's sake only, because it would only slide out when the unit isn't broken.
Below is the unit working correctly on the passenger side. Note how it slides freely on the track.
Here is my driver's side unit that is sitting on the track broken.
These units can be ordered, and others have posted the links to them. Also, if your jeep is under warranty, you can try that route.
But, here's an easy, temporary (or permanent) fix. I used a 14mm long sock I got from harbor freight. No other size would work for me. And it had to be red
--- in my case, the plastic unit broke when the seat was all the way forward up against the steering wheel. It wouldn't slide back at all, and I couldn't drive. I took a long 3/8 extension and inserted it between the door-side seat tracks, from the back. In the picture below, you can see the opening where the cap is. I pushed with the extension through that opening until the plastic unit broke free of being jammed in the tracks.
For the temporary fix, you must remove the plastic cap from the end of the top part of the track that slides with the seat. In the picture below I've laid the cap back up against where it would go. These have have several tangs, so be careful not to break. You need to remove this cap, otherwise the 14mm socket won't fit in there, and you need that large of socket to trip the lever.
Ok, once that cap is removed you can slide the socket between the top and bottom tracks. The reason you can't just set the socket anywhere in the lower track is that it will likely end up jamming.
Now, when you slide the seat back, it will trip whatever the heck is up in there that the plastic unit was tripping. Note, you must slide the seat as far back as it will go, and push the seatback to upright position. Now the seat will function like normal.
HOWEVER, the socked will not allow the seat to slide back fully. Use the bar under the seat (NOT THE SHOULDER LEVER) to slide the seat forward and then you can remove the socket. Now the seat will adjust like normal.
NOTE: Whenever you use the shoulder lever on the seatback to scoot the seat forward (to let someone get into or out of the back seat) you will need to use the socket again to release that mechanism, so that the seat will return to adjusting like normal.
It sounds a little complicated but here's the steps...
1. Use lever on seatback shoulder to scoot seat forward to let kids in back.
2. Insert socket into gap between upper and lower tracks, on door side track.
3. Slide seat all the way back until seatback releases
4. Use the bar under the front of the seat to slide seat forward.
5. Remove socket.
6. Use the bar again to slide seat back.
After all this, I'm debating whether I even want to bother replacing that plastic unit. I might just use the socket method. Because, if that plastic thing breaks when the seat is full forward, you literally can't drive. If you do replace the unit, be careful to slide the seat gently. The plastic unit slides independently, and it easily jams and breaks when the seat is handled roughly.
Hope that helps someone!
5. Remove socket.
