FIX for key fob key opening in my pocket every ten minutes.
jimbom
Jim
AZ
2020 6-Speed Rubicon Gator Gladiator, 2015 Infiniti Q60 6-Speed Sport Coupe (wife's, really), 2003 5-speed Honda Civic Coupe, 1960-something Jeep Gladiator (Matchbox)
I got an entire new fob. I believe AJT designs is the name. No more key problem.
Are those a new, smaller "shell" to put the guts of the existing FOB into? I assume the key part does not transfer. If that is so, do you just carry the key separately?
gnome
Bushnell, Florida
.... 1994 base YJ .......... 2006 Dakota ..... ..... 2020 Sahara 3.0D
retired IBEW electrician
Quetzal
ERIC
AZ
2019 Wrangler Rubicon JLU
Teacher
The fob from Amazon covers the existing fob like a glove, no alterations needed, and looks great. Even a cut out so Jeep logo shows through.
ChrispyJL
chris
Rockaway, NJ
2018 Punk"N JLU Sport s
Building Mechanic
I just got a dope man bag thing, phone, wallet, keys, snacks, water, knife, and some other essential medications stay in it, it goes wherever I go, havn't had to take out my key since I bought my jeep, I also don't lock the doors so there is that.
D60
CO
JL
I'm continually confused by putting things OVER the giant fob, taking it from giant to ginormous, but whatever floats your boat.
I've said it in the other threads, but I took mine apart, rigged the spring so it doesn't make the key pop open when the button is depressed, and reassembled.
I bought my JL in April '19 so I'm basically at 1 year of ownership and the number of times I've needed the actual key or regretted doing this: ZERO
Jeepers333
Jim
Phoenix, AZ
2018 Wrangler JLU
I had a bunch of O-rings and found the perfect size. Super glued it to the fob. Perfect! Thanks!
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
Detensioning the spring works great and does not interfere with the actual use of the key, for those of us with a sport. 1.5 years since I did mine with 0 opens in the pocket.
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
Shots
Winchell
Ohio
Wrangler Sahara (JLU), Renegade Limited (BU)
....I took mine apart, rigged the spring so it doesn't make the key pop open when the button is depressed, and reassembled.....
I did the same thing. By "rigged" all you have to do us release the tension on the spring (remove and reinstall), then put it back together. Very easy, and reversible if you later decide you want it spring loaded again.
With this method the key is still easily accessible/usable, but it won't flip out in your pocket. You press the release button and flick your wrist to swing the key out. No more pocket deployment, no bulky add-on, no inconvenience in using the key.
FWIW, I use my key quite a bit to lock the console and/or glove box, so I wanted to be able to use the key without extra effort, but I also hated the key opening in my pocket.
joshrude
Josh
Texas, USA
2018 Jeep JL Sport S
The new fob is about the same length but not as wide as the original fob. There is a built in slot for the key so I can still use it for the glove box/console. Pictures below. There are also a million different color combos for the fob(AJT Designs).
D&C Designs
