First Time Installing Lift
jdhunt0
Kentucky
2019 Wrangler Unlimited
I will be installing my 2in lift tomorrow in the garage. One question I have is how far will I need to drop the axle to swap springs? Would it be a horrible idea to put my axles on jack stands and use a forklift to raise the jeep to swap the springs? Or put the Jeep on tall stands and lower the axle to the ground?
Roky
Roky
You can use jack stands under the frame and use floor jack under the axle. With wheel off you’ll have plenty of room for 2” lift springs. No way I’d lift with forklift personally, knowing me I’d stick the forks right through the door....:facepalm:......:)
Carlton
Chicago
Jeeps lots of jeeps
Do not use a forklift.
Jack stands and jacks are the way to go.
Shots
Winchell
Ohio
'22 Rubicon
Yeah as Roky said, I wouldn't use a fork lift. They don't have the finesse you want/need when working with a vehicle. Just put jack stands under the frame, and lower the axle with the floor jack.
To answer the other question, you don't need to drop the axle far. I did a 2" kit on mine too, and it was pretty easy. A quick tip I'd give is to disconnect the rear track bar when you do the rear install. Doing that allows the axle to drop a little bit more, and makes getting the rear springs back in a breeze.
