robaw
Now I'm just confused. My transfer case shifter looks like this, apparently this video is from some other version of Jeep
The easiest and smoothest way, roll a little bit, like 2mph, slip transmission into N, and the Tcase will slide into 4L with ease. Much tougher when standing still.
4WL is great for plowing snow with the Wrangler. Mostly just go forward and backward at low speed . Very effective.In my opinion it’s best to try to anticipate the situation and shift into 4L BEFORE you absolutely need it.
You want lockers whenever you have differing amounts of traction left to right (or the most extreme version of that, a wheel in the air.)Can you give me a scenario for lockers?
On any surface with a little slip (loose dirt, snow, sand, ice, mud) a little wheel hop is not going to be too bad in terms of wear to tires, joints, driveline or the trail itself. It is not ideal, but the forces and durations will be pretty low (because the loose surface allows easy slip), so it is not a biggie. Doing it on very hard packed dirt roads or paved roads is just throwing money away in terms of parts and tire wear, and can be unsafe because the vehicle may not go where you point it or do what you expect it to do. So soft = fine. Hard = NO.All well-considered. Do you think a little binding/wheel hop in dirt is harmful?
I’ve not been inclined to think so, but am eager to learn if I’m wrong.
This is the best description of the purpose of the equipment I have read so far!You want lockers whenever you have differing amounts of traction left to right (or the most extreme version of that, a wheel in the air.)
With a transfer case and traditional diffs, you get 50% of the power sent to the front and 50% to the rear, but since open differentials are designed to allow powered wheels to turn at different speeds (so you can go around corners) it is easy to squander all that power off-road by spinning one wheel at each end. Lockers make sure that any wheel with traction puts its power to the ground. In effect, they are a fixed distribution of 25% of the power to each wheel, non-negotiable. Whatever wheel has traction will push you forward until other wheels get into traction situations. Lockers make it hard to turn, of course, but are absolutely critical for serious off-roading.
Best to anticipate the need for them before you get stuck and lose momentum, and then to switch them off as soon as you are clear of the obstacle to reduce tire wear, drive train wear and unnecessary trail damage. I tend to engage them progressively myself - rear first (because it is often all you need and an unlocked front makes it easier to steer), but if it starts to look messier than anticipated, I immediately engage the front too just to preserve momentum and clear the obstacle, then they are both switched right back off.
And since I am inferring from your question that you are probably new to the whole Rubicon situation, I will mention the other button right next to that locker switch - the electronic sway bar disconnect. Hit that button as you are approaching the trail at the same time you drop into 4-Lo. That swaybar is an on-road handling item that makes the Jeep handle better on road and corner with less body roll (virtually all cars and trucks have them), but off road on uneven ground all it does is increase the likelihood of a front wheel being held up in the air or at least very lightly loaded. Turning it off disconnects the ends of it and gives you the full axle articulation designed into your suspension so that the axle can track the contour of the ground and give the front wheels maximum contact (and traction).
Best of luck and be safe out there!
