Phatm9
Hello i just received my sidetrack lights and have watched the install videos and would like to know if you can help. I would like to have the white lights come on with courtesy li lights and be able to work them manually with my auxiliary switch- I read that I would need a inline diode- i haven't worked with 1 of those before so can you tell me which 1 should get and instructions on how it should be hooked it. ThanksWell if you want the white to work off of 2 different inputs (Aux and Courtesy) you would need to install an in-line diode on the courtesy light wire so that the Aux power does not back-feed and turn on your dome light when you turn on the Aux switch.
