First Look: Sidetrack LED System for Wrangler JL!
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
If you install this and need to take it in for ESS battery service/replacement tell the service advisor about the additional wiring. If they get to the battery by removing the fender instead of just the liner they might pull your wiring out if they don't know about it.
ORACLElights
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
  • Thread starter
  • Thread Starter
  • #92
Customer photo on Rubicon:
Cliebo
Craig
Ny
2018 Jl Sahara Unlimited
Instead of this being turned on manually by the dome switch can it we wired to an auxiliary light switch?
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #94
You could connect these to a switch if you prefer to have manual control of them.
Cliebo
Craig
Ny
i so before i pull the trigger and purchase i could have them wired to an aux switch while also having them wired to work with my turn signal and also key fob as in the video. Only difference would be instead of the inside light switch to turn it on it would be done with my aux switch? Sorry for all the questions . Product looks awesome btw
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #96
Well if you want the white to work off of 2 different inputs (Aux and Courtesy) you would need to install an in-line diode on the courtesy light wire so that the Aux power does not back-feed and turn on your dome light when you turn on the Aux switch.
Cliebo
Craig
Ny
thank you very helpfully
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #99
Great product! Just installed... any advice on how to route the white wire through the driver side on a manual transmission?
Looks great!
Manual is trickier than auto but here is the best spot.
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #101
I love these! Is it too late for me to get in on the group-buy?
Unfortunately, the group buy is over; but you can still get a deal for 10% your order with code forum10!
DanFelix
Riverside, CA
2018 Wrangler JL Sport S
I like these a lot, but the demos are all on vehicles with colored fenders. On non-black vehicles with black fenders they look a little too tactical for my pallet. Would prefer a set that does not occupy the entire brake vent indentation. Something a little more svelte. It is designed that way to allow the light enough height off the side to cast on the ground. I really like the non-invasive install. Perfect for leased vehicles that might be turned back at the end of the lease.
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #103
Thanks for your comments. We've designed it to fill the indent around the vent for a oem-appearing tactical-inspired body cladding. Here's a pic on a gray Jeep with black fenders.
DanFelix
Riverside, CA
That looks great. My comment is not a criticism. Some of us just are more attracted to a minimalist look. I have thought about buying your product and see If I can trim it down so it does not bring so much attention to itself on non-black, black-fendered JLs.
ORACLElights
ORACLElights
Metairie, LA
  • Thread starter
  • Thread Starter
  • #105
No worries, there may be some other product that would fit what you want better. I don't believe anyone has tried modifying this. Best of luck with finding the best for you!
Winjet
