First look at the Jeep Wrangler 4XE hybrid electric PHEV in the flesh!
AnnDee4444
JLR 2.0
I wonder what the water-fording height is???
Yikes!
Has anyone seen what happens to RC car Lipo batteries when they get wet inside, too hot, too cold, hit hard???
Yikes!
Just wondering because that’s the environment that Wranglers live in...
yikes.
So all we have so far is a logo, color scheme and a charging port? It's hard to get excited about this with no details to nerd out on.
I bet this is a display model and not an actual PHEV. They probably just added the cowl charge port and made blue logos & trim on a regular Rubicon. Oh, and the wheel paint is different too.
If you look closely, you can spot the red dashboard... shouldn't it be blue?
DanW
Indiana
I'd bet it is a real working pre-production model. The press is too sharp to pull off a badge job. Besides, they've most certainly had a good number of test mules out there running around right in plain sight. This close to the release date, there is no reason not to have a real one there. Wait until Roman and the boys at TFL start crawling all over it and they'll start giving us the details.
Night Ryder
Louisiana
Chrysler 200, Honda Odyssey
THe
Yikes!
Yikes!
They're going to rate it for 30" like every other Wrangler. It ought to be just as capable off road/in the mud as the E-Torque 4 cylinder. Take a look at that underside pic Jeep-Noob took. Everything is tucked up high
DWS44
Rock Hill, SC (Charlotte, NC Area)
2018 JLR (Ocean Blue) 2017 Corvette Grand Sport CE
CAD Manager (Civil/Airport Design)
That is the electric light colour coming from the display
It's not just the lighting. You can tell the decals and badging are really outlined in blue...and it even specifically mentions the blue accents in the article. ;)
Visually, the PHEV Jeeps look to be differentiated from their gas-only counterparts by a number of blue accents. In addition to prominent hood decals, the Jeeps' badges -- including the Trail-Rated logo -- are outlined in blue, which looks great against the show cars' gray paint.
ExitLeft
Wes
Philly ‘burbs
2003 Jeep Wrangler TJ
Got this one from someone on Facebook
Hybrid Electric Pages? That'll disappear 6 months after purchase (insert sarcasm). Then what?? LOL :LOL:
Seriously though, while I may not be in the market for it, I'm very curious/excited to see how this turns out.
JEEPN X 4
JEEPN X 4
N/A
Courtesy of Jeep-Noob who's at the show
They did a pretty good job with the battery placement. It is not any lower than the 2.0 eTorque battery, it just looks like it must be larger/longer. It's not any lower than the resonator on the exhaust. And it has what looks to be the same fuel tank as the non-EV models, so it should have 30+ miles better range when fully charged.
It would be interesting to see an underside pic of the front so we know what base motor we are dealing with.
You can also see the battery coolant lines draped over the driver side framerail.
I think from the earlier spy pics it could be seen that the front axle of this thing will have CV shafts. It's very cool that you can also schedule the charge times.
I'm optimistic about the pricing on this. It doesn't appear radically different from the packaging on the eTorque models. It will be more expensive than eTorque for sure... but will it be more than the diesel option? Maybe not...
JEEPN X 4
JEEPN X 4
N/A
LOL....yeah....NOTHING looks like it could go wrong with that position.
If you are regularly running double black rock trails, yes, I agree, it will get in the way, and this will not be for you. But really it it not that much lower than the EVAP on a JK. In a stock configuration the transfer case skid, trans crossmember, and forward section of the gas tank take the worst direct blows anyways. By the time you are cresting something the aft section of the gas skid usually just drags, which is about the same as what will happen to this battery skid. It's not for hard core rocks where you're at risk of regular and really hard direct blows to the battery skid. I'll agree with that.
Sean L
Sean
North Carolina
2018 Jeep Wrangler Sahara, 2017 Honda Accord Sport, 2003 Yamaha V Star 650 Silverado, 2014 Yamaha V Star 1300 Tourer
Looks like it has better protection than the fuel tank.
JEEPN X 4
JEEPN X 4
N/A
Same EVAP that JK owners are constantly cracking?
Seems ill-suited to a Rubicon package then....since rockcrawling is primarily what it's marketed to.
Only EVAP JK cracking failure that I'm aware of is the port that goes between it and the gas tank, and I don't think that has anything to do with the location of the EVAP skid. It's a fitting on top of the gas tank. Personally I occasionally hit the EVAP and have an Evo skid over it, but don't hit it with near the regularity of everything well in front of it.
There's rocks and then there's rocks. I'm pretty sure this thing will make it through Jeep's negotiation of the Rubicon. It seems unlikely that anyone is buying this expecting to take it through JV or similar stuff.
Sean L
Sean
North Carolina
Well, being smaller in surface area definitely helps. Just seems pretty vulnerable....but to be honest, where else are they going to put it?
As discussed earlier....seems like electrification on this non-dedicated platform makes a lot of compromises. It's the nature of the beast when you retrofit something that wasn't initially designed to perform a certain function.
I would say just as vulnerable as anything else under there, and my differentials are scraped up more than anything else down there. Obviously when you purpose build something like you have you have the luxury of putting the components where you need them to fit your specific needs. You really can't have a fully dedicated rock crawler that isn't good for anything else as a mass produced vehicle. But fortunately this hybrid is only an option and nobody is forcing anyone to buy it, so if you don't think it will fit a specific direction for a build, then you just get the Jeep you want.
For someone like me who daily drives the Jeep to work, church and grocery store (but never to the mall :lipssealed:) and only off roads on a few weekends this would be an interesting option.
