First look at production 2.0L 4-Cylinder Turbo Hurricane engine
rodhotter
bernie
pennsylvania USA
2008 chevy colorado 2001 audi TT 225Q
without the water cooling oil selection is even more critical for turbo health or not. typically OE turbos are sized for better response + low end torque, but with direct injection aggressive tuning is possible without pinging!
jmr
St. Louis, MO
'22 JL Willys
jmr
St. Louis, MO
'22 JL Willys
I have not found that information yet or how much boost it makes.
rodhotter
bernie
pennsylvania USA
OE's are cheap so no ball bearings + prolly no more than 10 lb boost for reliability. only performance minded models see higher boost. my 01 jetta showed 7 lb stock on the gauge i installed the 01 WRX i tested showed 15 on its factory gauge but very doggy at lower rpm's to protect their AWD. todays DI turbo'd engines can boost sooner + faster as well as more without spark knock, IF the ECU lets it. you can "cheat" to get more boost but without proper fueling your engine can be ruined! of course any modifications will likely void your warranty
FUHL
Robert
Sandpoint Idaho
cmott426.wixsite.com
2013 F-150 Ecoboost 2018 2-door Rubicon 2013 Range Rover Evoque
CAD Drafter/Engineer
Apparently it makes 24psi.
https://www.jlwranglerforums.com/forum/threads/boost-guage.17970/
AnnDee4444
'18 JLR 2.0
I would bet it is more than 10 psi.
If you go by the theory that each atmosphere (14.7 psi) roughly doubles the power output, 10 psi would mean that a without the turbo the 2.0L would make about 150-160 ft.lb. or torque. 80 ft.lb. per liter would put this motor near the top of all motors ever. I would bet that the boost is closer to 25 psi for such a small motor to make 270 ft.lb. of torque.
