mgroeger
- Mike
- Feb 1, 2018
- Hurricane, UT
- 2021 JLUR 2.0T, 1991 YJ rock crawler
- Occupation
- I make microchips for a living.
- Vehicle Showcase
- 1
WOW! I can't believe someone would go through that hassle to save a few bucks. Unreal, imagine if they spent that much effort on doing something positive... they'd probably accomplish a lotWell, I think the no foil seal concern you have is unwarranted. Many/most no longer use a foil seal.
This is the year 2018. There is really no need for the foil seal.
I do suggest that when you go to buy the 5qt. container at your local store to be sure the top of the plastic bottle is sealed. You will feel the seal let loose/"crack" when you open the jug. IF you do not feel the seal break/let loose, return the bottle to the store and get another..
Why.... There are worthless assholes out there.... that will buy premium oil and dump it out of the container into their own container...... then they put cheaper, crapola oil in the newly purchased container and return that container for a refund. Last year, I actually checked a new 5 qt. jug in the store parking lot to see if it was sealed and it had friggin used oil in it.
