I think the 2.0 must have a better torque curve. My 3.6 with 37s would be in 6th or 7th at 80 be fore I regeared.
Actually, the V6 has a broader power band that starts at lower RPM.
The 2.0T produces slightly more power but on a narrower band at higher RPMs; you’d be on the turbo the whole time...or pretty close to it.
Regarding the 2.0 vs. 3.6 endless battle... one thing I never see brought up is that the 2.0's lower redline means that it will need to go through the gears quicker when accelerating, which is exactly what happens when you change differential gears. A 4.10 geared 2.0 will shift to second gear faster than a 3.6 with 4.10s (and every following gear). Even though the 2.0 isn't geared lower, WOT acceleration will utilize more gears quicker (similar to a 3.6 with lower gears). To get a 3.6 to shift at the same time as a 2.0 with 4.10s, it would need a gear ration between 4.56 & 4.88.This - the 2.0T definitely makes more power but I'd be concerned with turbo longevity with larger tires and lots of armor especially if you don't regear.
Just texted my dealer...he said 35" Tire suspension, I said when I ordered Jeep advertised 1.5" lift....he doesnt have an answer but im at the point of no return...was gonna drop the Recon package but cant now so only option if true is that I cancel and lose my $500 deposit.OK so figured I would ask Jeep chat. They said it does have a 1.5" factory suspension lift. Emailed my dealer as well with same question. Waiting on that response. So if it ends up actually not having one then I see that as being a big issue for them.
does the build sheet say anything about the suspensionMy window sticker calls it a 35 inch tire package. Nothing of lift or suspension components…
“35 inch tire suspension” on my cryptostickers build sheetdoes the build sheet say anything about the suspension
My build sheet shows 35” tire suspension...does the build sheet say anything about the suspension
If there is no lift, Jeep changed the package after you ordered. The dealership owes your deposit back.Just texted my dealer...he said 35" Tire suspension, I said when I ordered Jeep advertised 1.5" lift....he doesnt have an answer but im at the point of no return...was gonna drop the Recon package but cant now so only option if true is that I cancel and lose my $500 deposit.
It is looking more and more likely that Jeep pulled a bait and switch. Advertise a lift then send out jeeps with no lift and giant bump stops.My
The wording change to 35" tire suspension is really adding fuel to the fire of no actual "lift". Rubicon's with highline fenders were also noted as being capable of up to 35" tires with added bumpstops (to keep from hitting fender). I have a bad feeling they just updated the bumpstop design to ensure no rubbing.I’ve got an XR on order. I’m gonna be seriously pissed if there’s not an actual lift. Bump stop extensions aren’t going to cut it.
Yeah. If the spring part numbers are the same as a regular Rubicon then that pretty much settles it, no?The wording change to 35" tire suspension is really adding fuel to the fire of no actual "lift". Rubicon's with highline fenders were also noted as being capable of up to 35" tires with added bumpstops (to keep from hitting fender). I have a bad feeling they just updated the bumpstop design to ensure no rubbing.
looking at the pictures it really looks like regular Rubicon shocks and springs, with the 392 swaybar links and longer bumpstops.
