First aftermarket JL LED Tailights
Brooklynjlu2018
Junior
Massachusetts
2018 wrangler sahara
Now if i have factory led package do i still need the load resistors with these
Wrangler847
NY
wrangler
I had no clue what to do with those and just kept em away from wires when I put em in. :facepalm:
Brooklynjlu2018
Junior
Massachusetts
Just ordered these sequential led taillights. 300$ shipped supposedly have the blind spot monitoring and no error message for those of us who have the factory led package because those other ones that everyone is using did not work in my jeep because i had the factory led package
Brooklynjlu2018
Junior
Massachusetts
just found this as well
blnewt
New Mexico
Just ask @cosine he knows!
Should start a new thread " Second LED tails available" :)
look forward to reviews on them, FWIW mine are still working superb!
Du0377
Bobby
Phoenix, Arizona
2019 Jeep Wrangler JLU Sport S
Medical Student
Smoked looks great, but will these aftermarket tail lights work on JLs with LED pkg? Any issue with the BSM?
Hey I know this is old, but with the led package you wouldn’t need a resistor because you are already drawing less power. The resistor is wired in parallel with the circuit. If you just cut out the resistor and install you would be fine. The resistor is there to essentially trick the jeep into thinking the halogens are still installed and you don’t get a hyper-blink in the cabin.
wyobob44
Bob
Sundance Wy
2019 Jeep Wrangler JL 2.0 , 17 Indian Chieftain, 12 Ford F-350 Dually 4X4, 74 Jeep Wangoneer
I just installed a set in my JLUR that came with Factory LED and i get the message on the dash Turn Signal Lights Out, hyper flashing on turn indicators on dash, but both lights outside blink at proper rate.
So i just cut out the resistor and cap off the wires??
blnewt
New Mexico
Looks like you can get them for under $100 now.
https://www.aliexpress.com/item/33002804197.html
FWIW these lights are a great addition to non LED JLs, have had nothing but positive comments and they have performed flawlessly. Only two caveats, the reverse LED isn't very bright (same complaint as the stock reverse light for those JLs w/ the factory LED set). And the gloss lens cover needs to be cleaned w/a very soft microfiber cloth as it's easy to scratch (but can be buffed shiny again). So I would recommend a reverse light bar such as this~
https://www.jlwranglerforums.com/fo...t-bar-on-jl-sport-plastic-bumper-cover.31728/
lanman08
landon
wilmington, nc
2018 Jeep Wrangler Unlimited Sahara JL
Has anyone found any aftermarket lights like the smoked ones mentioned in this thread without smoke covering/ie like the factory? If so where did you get them
sheogorath
saudi arabia
2018 wrangler JLU rubicon. camaro ss fifty
You can finde the non smoked European style on aliexpress
