Finally got my 35 inch tires on
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
Well, Yesterday I got my tires and xd wheels installed. Looks pretty bad ass. I opted for the ridge grapplers instead of the KO2's. I was really no the fence but figured I would try them.
The ride is definitely a little different but not in a bad way. I notice the bumps a lot more.
The Psi is 37 right now because they didn't want my TPMS sensors going off. I know i have to get them calibrated to make them accurate. Anyone know the recommnded psi from Nitto for the 35's on a JL rubicon?
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
Ohh man.. I was hoping for a picture :(
ECHO
Craig
Pennsylvania
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Looks good to me
mike_b_81
Iowa
2019 JLUR
I was running 30-32. The thing with the Ridge Grapplers, they’re probably a load range E, so unlike the KO2, which is a C, they’ll be stiffer, so even running a little lower tire pressure you’ll still probably notice more bumps.
LLRubylady
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
  • Thread starter
  • Thread Starter
  • #7
Yes they are load E. I don’t mind the bumps really. It feels more Jeep like to me. I was originally going to get the ko2 but then changed my mind. I think these look way better. We will see how they perform. Driving in rain scares me more than snow.
stangken
Ken
Longmont, CO
BMW 335i/Triumph Thruxton R/Suzuki SV650
Stock suspension?
What offset are those wheels?
More photos!
LLRubylady
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
  • Thread starter
  • Thread Starter
  • #9
Stock suspension?
More photos!
Yep. Stock rubicon suspension. No lift. Wheels are 17 x 9 XD holeshot. Don’t know the offset.
I’ll see if I can find it on their website.
stangken
Ken
Longmont, CO
17x9 appears to be -12
17x8.5 = +34
LLRubylady
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
  • Thread starter
  • Thread Starter
  • #12
Your new wheels and tires look great!
Thanks. They sure are heavy though. I have the Mopar reinforcement on the tailgate. I can definitely feel the weight in it when opening it. It’s not sagging so that’s good.
I hope it holds up.
LLRubylady
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
  • Thread starter
  • Thread Starter
  • #13
Looks great! Also great choice in tires, I’ve been running these since they came out. They’re a little stiffer but that doesn’t bother me, they’re extremely durable, and perform great off road. I run 32 psi in mine. You should calibrate your speedometer if you haven’t already . The tazer jl mini is what I have if you have this programmer the setting is 34.73 I believe. This will get your shift points back to where they need to be, and a more accurate read out on your gas mileage, you can also lower your tpms sensor with tazer, so it doesn’t aggravate the crap out of you. :)
doesn't the taser void warranty because they can tell if you've had one plugged in? I just figured I would go to the dealer and have them calibrate.
Roky
Roky
North Central Florida
I’m not sure about the warranty, but if you unmarry and remove it before you take it in, Jeep goes back to factory settings. That’s what I do just in case. And don’t mention it. I’ve had mine in several different times and no issues. The dealer is going to charge you a couple hundred bucks and use it once , for another hundred you’ll have something you can do a lot more things with, like disable stupid auto stat/stop unless you like using it. If you reach out to @Rhinebeck01, he’s really knowledgeable on this, can explain it better than I can, but it’s super easy, trust me if this old caveman can do it, anyone can. :)
LLRubylady
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
  • Thread starter
  • Thread Starter
  • #15
Not sure I like the 35s yet. I love the way they look, just driving seems a little different. I suppose the recalibration may help that. It's only been one day. I'll have to drive it a bit more.
I am a little concerned about extra wear and tear because of the weight and rotational mass, but was assured it should be a non issue because 35s aren't too bad.
Quake LED
