Fender mount GMRS antenna and under seat power (pic heavy)
jeepdriver99
JD
Central Ohio
JL 2-door Rubicon, 15 Renegade, 06 GC, 67 Jeep M725, 54 Willys SW (WIP)
W8BWD
I didn’t know about the paint issue. Good to know! I’ll need to scrape mine this weekend.
Can you explain how you checked it with an ohm meter?
Using the Volt/Ohm meter, I checked at the radio end of the coax between the shield part of the connector to the ground on the passenger side. That showed continuity from the body to the shield of the coax. I also checked the tip to the shield which showed an open so I knew there was no short in the coax at any point. The only place the coax was in contact with the body was at the rear of the Jeep at the antenna mount.
Dkretden
Denver, CO
2020 JLUR 3.6L
@jeepdriver99
the antenna that you linked to is fairly short. Seems like it doesn’t extend beyond your roof line. I see that you have a soft top on in the picture. Do you also have a hardtop and, if so, does this “short” antenna work equally well with a Hardtop?
jeepdriver99
JD
Central Ohio
W8BWD
@jeepdriver99
It comes about 3 inches above the soft top. I don't have a hard top. If the hard top is all fiberglass, then it shouldn't have an appreciable effect. I don't know about what effect it will have with the metallic portions of the lift gate. I do have the roll bar about a foot from the antenna but I still have great results with it and my SWR is 1.2 to 1.
Dkretden
Denver, CO
2020 JLUR 3.6L
Thank you!!!!!!!
Xtremetj
Greg
2019 F350 Platinum, Ignot Silver, 2019 Rubicon Unlimited, Billet Silver
Oil & Gas Environmental Rep
Following as I try and figure what I need to do.
Currently running a Uniden 760 CB but got my license to start using the GMRS radios.
I‘m not fond of the look of the antenna on the hood. Would really like to be able to use/convert my current CB antenna setup off the back of the Jeep on my JCR spare tire carrier. Is this even possible?
Frezski
Allan
Central Coast, California
2019 JLUR, 2013 F250, 2016 Accord, 2016 Yami R1M
Slave to the Trade
It's really a hard give and take. I too prefer to mount my antenna in the rear, but either there isn't enough space or finding a proper mount are far and few in between unless you fab one up or pay a fabricator to do it. I personally am not a 100% fan of how I have mine mounted but it works and I figured it could buy me time until there are more out on the market. I threw a bunch of GMRS antenna parts together and bought a deeper base because I wasn't sure how I wanted to do it just in case I was going to use the whip mount in a pinch. (That's why the connector hangs low). Obviously it over hangs because the mount was originally made for a CB and I had that laying around. I just made it work and haven't looked back. At some point I am going to move on from that tire carrier and that antenna set up, so that could be a factor I will consider when I cross that bridge. It has been on for about a year and worked flawlessly. The issue is the diameter of the NMO mount is a lot larger than that of a CB. Also, the frequency band of the antenna and radio is different from that of a CB as well.
mikej
mikej
  • Thread starter
  • Thread Starter
  • #22
Another option is to pursue one of the puck style GMRS antennas and mount it on your sport bar. I didn’t investigate this as I knew my rack would interfere.
https://www.jlwranglerforums.com/forum/threads/gmrs-antenna-mounting.7307/page-4#post-1112849
Xtremetj
Greg
James_a
Alameda, CA
2003 Rubicon, 2018 JLU Rubicon
Nice install. But it seems more complicated than necessary. I used a Comet hood GMRS NMO mount that is held on by tension screws to the hood, and fed the cable through the factory rubber grommet in the firewall - located under the brake booster and where the clutch pedal would go if you had a manual instead of the auto. Just needed to drill a small hole through the grommet and feed the cable through and seal with RTV sealant, and run it to your GMRS receiver (I installed mine in the glove box next to a Uniden CB brain box.
I like the way you mounted the antenna. Do you remember which model Comet hood GMRS NMO mount you used? I took a quick look and it seems they have a few different ones.
Hudson
PNW
2020 JLR
Here is the antenna and the hood mount. I also added an optional spring insert for the antenna that allows it to bend. Bought all of these from the Antenna Farm online.
Note: the mount comes with antenna cable long enough to reach the Midland or Ham Inside the Jeep. You need to unscrew the end of it to be able to feed the cable through the drivers side grommet. I drilled a hole from the engine compartment through the rubber grommet into the cabin, the fished the cable through the hold, then fished behind the dash. Finally, I used some RTV sealant to weather seal up the gap where the cable goes through the grommet.
James_a
Alameda, CA
Thank you!! Time to go shopping.
Stormin’ Moorman
Michael
Georgia
2019 JLUR
Forester
What kind of range are you guys getting? I have the Midland radios installed in my and my wife's jeeps and the range is pretty terrible, basically line of sight. It's just the factory antennae at this point and I'm looking for more range.
safety_glasses
2018 JLU Rubicon
Any VHF/UHF radio is line-of-sight, so you're going to get similar results. The higher the antenna and more power, the further the range.
JocoRubicon
Clayton
2020 JL Rubicon
Any issues with running the CB and GMRS antennas on the rear? I have the cool tech gmrs mount but have been considering adding a CB just for a failsafe, perhaps on the left of the spare. The question really is can I run both antenna cables along the same path, essentially together?
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I don't understand mounting electronics under the seat. I have had this happen a couple times, and I don't think the radio would fair well.
Hothead Headliners
