I have the rcv with fad delete. No vibes or problem for me. Roky does too with aftermarket driveshaft and his is just fine as wellNecrothreading via search.....
Who's running FAD delete?
I'm seriously considering it...any problems on the highway? I've presently got the MetalCloak front CV d/s and just wondering about noise/harmonics.
I'll have to go take a drive in 4hi at highway speeds to get a feel for it. I've already got a Tazer so the electronic side is easily handled
I run the UD44 which has no FAD. No issues at any speed. Disabled the electronics side with the tazer. No issues with that either.Necrothreading via search.....
Pardon my ignorance but the UD44 does not have lockouts at the wheel hubs, I'm assuming?I run the UD44 which has no FAD. No issues at any speed. Disabled the electronics side with the tazer. No issues with that either.
Nope, it just has the same unit bearings as the regular 30/44. I wish they had put some lockable hubs on it! That would have been sweet. It did come with new chromoly shafts w/ 1410 U-joints.Pardon my ignorance but the UD44 does not have lockouts at the wheel hubs, I'm assuming?
How are you planning to get manual lockouts?When ready I’m going old school. FAD delete with lock out hubs. Best of both worlds.
Teraflex made a conversion for the JK 44. Not sure about the quality of it or if they’ll make JL version.How are you planning to get manual lockouts?
But yeah, definitely best of both worlds. Too bad old stuff is now an "upgrade"
I spoke with Dynatrac at the off road expo and they said I could do it now but have to change knuckles ? I’m going to wait a little bit and see what develops in the aftermarket. I might just pop the housing out have them change the long side tube to solid and 1 piece axle add lockout hubs. But I’m also thinking about maybe just changing the whole axle assembly and selling the factory Rubicon front. Dynatrac not cheap. You’re totally right it’s sad that we have to use old stuff and old ideas. I want the same set up my 79 bronco had LOLHow are you planning to get manual lockouts?
