Factory Plastic to Steel bumper swap
Jeep1967
Ohio
2019 Rubicon JL, 2008 Sahara JK, 2000 Sport TJ, 1995 Sport YJ
Hi. I have a 2019 Rubicon with plastic bumper. I purchased a used factory steel bumper from a forum member and wondered about a few parts I think I am missing. I have the bumper, the two stubby ends, the skid guard and brackets. I wondered about plastic trim panels that would sit above bumper to fill gap between bumper and grill. Pictures and part numbers would be appreciated. I don't have a winch. It just looks sort of empty in that area. My plastic bumper had a filler piece of trim that was in that area. I don't think it is the same for the steel bumper. Thanks
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
There is a Closeout Panel Part # 6BU43RXFAB
You can to Maximus 3 and they sell some filler plates for the back of the bumper as well others depending on your configuration
grady2hig
Wisconsin
2018 Rubicon JLU, 2017 Toyota Sienna XLE 4WD
No Filler for the steel bumper, you can to Maximus 3 and they sell some filler plates for the back of the bumper as well others depending on your configuration
There is a trim plate Part #
So it also drops the Jeep about 1/2 inch i hear.
ECHO
Craig
Pennsylvania
I don't think its that heavy by itself.. when you add a winch then yes 1/2" - 3/4" is normal .. I lost 3/4" just added spacers to make up[ the difference
grady2hig
Wisconsin
oh yeah, I think it was with winch I heard.
ECHO
Craig
Pennsylvania
Good Deal, if you get a winch with a steel cable, that adds almost 70lbs by itself
Jeep1967
Ohio
Thanks for the input - so is there a trim plate? No part number shown?
Is the closeout panel used on the steel bumper?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
The part is the same between the two bumpers, why not reuse the one from your plastic bumper? Why not just install a winch?
Jeep1967
Ohio
So the plastic piece from my old plastic bumper is the same? That is good news. It looked too skinny for the job. As far as the winch- - - - - $$$ is not what I have right now.
TJ2018
Eric
Orange County, CA
2018 Punk'n JLUR; 2020 Silverado Trail Boss
You'll also need to add (4) rivnuts for the skid plate mounting bracket (steel uses different locations than plastic). Use caution when installing as I managed to destroy more than 1 rivnut during installation (and they are a pain to get out).
Trail Recon did a great video of swapping the bumpers... definitely recommend watching it!
Jeep1967
Ohio
Hi again. So the plastic close out panel for the plastic bumper is same as steel? I put it on but it sure looks weird. There are holes where it used to attach to the plastic bumper not used by steel? Is this correct?
Whipper25
JL Sports S
It is not the same closure panel. You will need to get the steel closure panel for the steel bumper. The part number for the steel closure panel is 6BU43RXFAB
Jeep1967
Ohio
Thank you for the information.
Quadratec
