Nghteyes
Thank you very much for doing that. I greatly appreciate it. Could I ask what kind and size 37s you put on?I just went out and put a straight edge across the top of the soft top on its highest point and then dropped a tape measure from there to the ground and I measured out at 79” to the ground. Strange you say your Jk is the same measurement with a 2” lift and 35’s... If you still have 6” of clearance before you hit anything you will be fine. you will not come close to that with this set up.
Thank you
