Yeah I planned on snapping some on lunch. Yeah looks like it would bolt up fine and there are three other mounting points anyway along with the bracing there would be no issues. If you are OCD you could put some epoxy on it and it would be 100%.Do you have any pics? Would it still bolt up with the tear in the tab?
Not 100% on that but when I ran the part number it did come up with Sport and Sport S in the compatibility. Not a guarantee but definitely there...If only this worked as a direct swap for a JL Sport S I would def purchase it
I dont think they will work on a non LED optioned jl unless you have a tazer.Not 100% on that but when I ran the part number it did come up with Sport and Sport S in the compatibility. Not a guarantee but definitely there...
https://www.mymoparparts.com/oem-parts/mopar-park-turn-lamp-55112884ae?c=az0xJnE9NTUxMTI4ODRBRA==
Gotcha. Thanks! Didn't know the plugs were different.What I have read, looks like you can do it on a Rubi or Sahara because it has the four prong plug. Sport’s only have three since it is not an option. You will need a Tazer to switch from Halogen to LED
Still available, im interested in buying. [email protected]Updated with pictures. Wiring is all in perfect shape.The tab is shown on the last pic. It is still pretty solid (I'm assuming from the thickness of the plastic). As stated before it does not look like it was effect the mounting at all.
Yup still up for grabs. Responded back to your PM.Still available, im interested in buying. [email protected]
