Akbill
Disregard- I forgot to turn on the physical switch for number four, It works fine. I don’t know how to delete this post for this thread that I started.
problem: Factory Aux 4 no power
I get no power with JLUR 2019 running, Aux #4 blue/pink aux wire under dash. # 3 works fine. fuse F108 is good as is relay K21 after testing. same 4 aux wire under hood also has no power. Setting are on for ignition, tried last power state on and off. tried battery setting for #4 also.
what to check next?????
OOPS I FORGOT THE Actual Factory SWITCH- it works
