Thanks for posting. It looks awsome with the lift. They didn’t give the height but there is a significant difference there between stock and lifted. Think it might be touch and go with my garage. I’ll drop them a comment and see if they can give me the exact height. Does anyone know if you can use the stock rubicon wheels with 35” tires? Will they fit? Will they look weird?
.. and how tall is your garage?I have 35's with a 2 inch lift and still have 7 inches clearance on my garage.
I was wondering the same thing since the Rubi has the high fenders, if it might make it look too tall for the tires.Curious what the 4dr Ruby with Mopar lift looks like with the standard Ruby wheels and tires. When I get my JL, I was planning on going ahead and getting the 2" lift from Mopar but wondering how "odd" it would look w/o the bigger tires.
Did you simply put some spacers under the coil springs to get some added lift? Probably if the owner only wants an inch or so of lift, that seems a good way to go and much less expensive than new control arms. Do you envision any downside in terms of caster change or shocks reaching their end point with a limited coil spacer type lift? I've only owned leaf spring Jeeps, but it seems to me the caster change from a one inch spacer lift would be fairly minimal? Not sure if two inch would be pushing it.I agree on the dealer hype.
I have $20 invested in my budget boost lift, albeit it is only temporary until I can build a full lift.
