fst96se
This Factor 55 Ultra Hook has been mounted on my winch, but not used. It is in absolutely perfect condition, virtually indistinguishable from new, and includes the box.
The industry’s first winch hook with an integrated shackle pin mount
Two methods of use: conventional hook opening, or shackle mount
Shackle pin mount allows the safer practice of Closed System Winching
Finger grip feature promotes proper “Hook Up” orientation
Double locking safety clasp – lock the safety clasp with the included clevis pin
Latch lock clevis pin stored conveniently in hook body
Integrated EPDM rubber pads for fairlead surface protection
Max opening deformation clearly laser engraved
Lightweight – Precision CNC machined 7000 series Military Grade Aluminum
No rope splicing required – double shear pin design accepts rope/cable eyes
Designed for both steel cables and synthetic winch ropes
Foldable to stow rattle free against fairleads
Shackle pin mounting hole accepts ¾ shackle pins (.875” diameter)
For rope and cable diameters up to 3/8’’
Available in the Military Specification Hard Anodizing (Mil-A-8625 F Type III) Gray
5/8” diameter 6AI-4V grade V titanium double shear pin
Max Rated Load: 16,000 pounds
Ultimate Strength – Hook Throat Opening: 31,000 pounds
Ultimate Strength – Shackle Pin Mount: 48,000 pounds
Weight: 32oz
MADE IN THE USA
Weight: 32oz
MADE IN THE USA
